2 Replies Latest reply on Oct 4, 2011 12:51 AM by bugrake
    java servlet failing on client site
    bugrake
      ALC-DSC-031-000: com.adobe.idp.dsc.net.DSCNamingException: Remote EJBObject lookup failed for ejb/Invocation provider
          at com.adobe.idp.dsc.provider.impl.ejb.EjbMessageDispatcher.initialise(EjbMessageDispatcher. java:97)
          at com.adobe.idp.dsc.provider.impl.ejb.EjbMessageDispatcher.doSend(EjbMessageDispatcher.java :130)
          at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispat cher.java:57)
          at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
          at com.fourpointsolutions.ps.client.dcc.CallLCFormRenderServiceServlet.doGet(CallLCFormRende rServiceServlet.java:74)
          at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
          at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
          at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:290)
          at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
          at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
          at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:235)
          at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:230)
          at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
          at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.ja va:179)
          at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:84)
          at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
          at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:104)
          at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java: 157)
          at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
          at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:241)
          at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
          at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.ja va:580)
          at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
          at java.lang.Thread.run(Unknown Source)
      Caused by: javax.naming.CommunicationException: Could not obtain connection to any of these urls: localhost:1099 and discovery failed with error: javax.naming.CommunicationException: Receive timed out [Root exception is java.net.SocketTimeoutException: Receive timed out] [Root exception is javax.naming.CommunicationException: Failed to connect to server localhost:1099 [Root exception is javax.naming.ServiceUnavailableException: Failed to connect to server localhost:1099 [Root exception is java.net.ConnectException: Connection refused: connect]]]
          at org.jnp.interfaces.NamingContext.checkRef(NamingContext.java:1416)
          at org.jnp.interfaces.NamingContext.lookup(NamingContext.java:596)
          at org.jnp.interfaces.NamingContext.lookup(NamingContext.java:589)
          at javax.naming.InitialContext.lookup(Unknown Source)
          at com.adobe.idp.dsc.provider.impl.ejb.EjbMessageDispatcher.initialise(EjbMessageDispatcher. java:88)
          ... 24 more
      Caused by: javax.naming.CommunicationException: Failed to connect to server localhost:1099 [Root exception is javax.naming.ServiceUnavailableException: Failed to connect to server localhost:1099 [Root exception is java.net.ConnectException: Connection refused: connect]]
          at org.jnp.interfaces.NamingContext.getServer(NamingContext.java:269)
          at org.jnp.interfaces.NamingContext.checkRef(NamingContext.java:1387)
          ... 28 more
      Caused by: javax.naming.ServiceUnavailableException: Failed to connect to server localhost:1099 [Root exception is java.net.ConnectException: Connection refused: connect]
          at org.jnp.interfaces.NamingContext.getServer(NamingContext.java:243)
          ... 29 more
      Caused by: java.net.ConnectException: Connection refused: connect
          at java.net.PlainSocketImpl.socketConnect(Native Method)
          at java.net.PlainSocketImpl.doConnect(Unknown Source)
          at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
          at java.net.PlainSocketImpl.connect(Unknown Source)
          at java.net.SocksSocketImpl.connect(Unknown Source)
          at java.net.Socket.connect(Unknown Source)
          at java.net.Socket.<init>(Unknown Source)
          at org.jnp.interfaces.TimedSocketFactory.createSocket(TimedSocketFactory.java:84)
          at org.jnp.interfaces.TimedSocketFactory.createSocket(TimedSocketFactory.java:77)
          at org.jnp.interfaces.NamingContext.getServer(NamingContext.java:239)
      We have deployed a java servlet on a client site which fails when connecting to the process [ EJB ] see above. Works fine on development and test sytems, including when accessed remotely on these systems. It is a standard form render. What should I be checking out ?
      Should I rebuild the deployed war on the client site ?
      Should I replace localhost in the following line with the server name ?
      ConnectionProps.setProperty("DSC_DEFAULT_EJB_ENDPOINT", "jnp://localhost:1099");
      Are the account and password setting used in this context ?
           connectionProps.setProperty("DSC_CREDENTIAL_USERNAME", "administrator");
            connectionProps.setProperty("DSC_CREDENTIAL_PASSWORD", "password");
      They have SSL set up - will this have an impact ?
      thanks for any help
