4 Replies Latest reply on Sep 9, 2011 2:28 PM by kglad
    Date Chooser - odd behaviour ? !
    Tony Heagren Level 1
      Hi all,
      I'm playing around with a booking system and thought a date chooser might suit my needs.
      Each "set" button on the stage opens (makes visible) the same DateChooser component and when the date is
      clicked timeline code on frame 1 delivers the data to a dynamic text box (code at the end of this post).
      My issue is when the date is clicked in the "calendar" the info is delivered to a dynamic text box and it displays
      in one of two apparently random formats (see picture) i.e. with or with out "GMT+0100" on the end of the string.
      So my question is how do I manage / manipulate / control the formatting of the data ?
      I ideally want it presented like this: Saturday 27th September 2011  (with NO time included).
      NB - the "set" on the left and the "am" on the right are just buttons and graphics on my stage.
      All and any help / tips / links tutorials much apprecited.
      Best wishes
      Tony
      "set" button code:
      _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
      on (release) {
          calendar_dc._visible = 1
          quando = 1;
      timeline (frame1) code:
      var dcListener:Object = new Object();
      dcListener.change = function(evt_obj:Object) {
      var thisDate:Date = evt_obj.target.selectedDate;
      if (_root.quando == 1) {
          date1 = thisDate;
      } else if (_root.quando == 2) {
          date2 = thisDate;
      } else if (_root.quando == 3) {
          date3 = thisDate;
      } else if (_root.quando == 4) {
          date4 = thisDate;
      } else if (_root.quando == 5) {
          date5 = thisDate;
      calendar_dc._visible = 0;
      calendar_dc.addEventListener("change", dcListener);
        • 1. Re: Date Chooser - odd behaviour ? !
          use:_ _ _ _ _ _ _ _ _ _ _ _ _
          var monthA:Array=["Jan","Feb","Mar",etc..];  // use whatever format you want
          var d:Date = evt_obj.target.selectedDate;
          var thisDate:String=d.getDay()+" "+monthA[d.getMonth()]+" "+d.getDate();
              date1 = thisDate;
              date2 = thisDate;
              date3 = thisDate;
              date4 = thisDate;
              date5 = thisDate;
          • 2. Re: Date Chooser - odd behaviour ? !
            thanks for helping - I tried this (code below) and got a syntax error
            for line 1 (the aray) - any ideas ?
            Best wishes
            Tony
            var monthA:Array =
            ["January","February","March","April","May","June","July","August","Sept
            ember","October","November","December"];
            var thisDate:String=d.getDay()" "monthA[d.getMonth()]" "d.getDate();
            // MY version !
            //var dcListener:Object = new Object();
            //dcListener.change = function(evt_obj:Object) {
            // var thisDate:Date = evt_obj.target.selectedDate;
                 date1 = thisDate;
                 date2 = thisDate;
                 date3 = thisDate;
                 date4 = thisDate;
                 date5 = thisDate;
            • 3. Re: Date Chooser - odd behaviour ? !
              Scratch that - fixed it with exactly your code.
              Must have been some random white space from the cut and paste.
              Thanks again.
              Tony
              • 4. Re: Date Chooser - odd behaviour ? !
                you're welcome.
