0 Replies Latest reply on Sep 8, 2011 3:09 PM by jvenkatrao
    Problem with RepositoryClient
    jvenkatrao Level 1
      I have a PDF form that I copied/wrote to LiveCycle server folder using
      RepositoryClient API (writeResource) from my local system. The Write
      operation was successful. But I do not see this form when I
      synchronize my folders from within Workbench. I do see it when I try
      to read it using readResource method and also when I list all the
      members in the folder.
      How do I see this PDF form from the workbench ? Another thing I notice is that when I list the members of the folder where I am writing the resource to, for the new resource I wrote, I do not see a file with extension 'pdf_dci' that gets created for every form.
      Here is my code.
      String fileName = "C:\\My Documents\\WriteResource.pdf";
      String LC_FOLDER_PATH = "/Applications/Test/1.0/Forms";
      File iFile = new File(fileName);
      try {
      FileInputStream inputStream = new FileInputStream(iFile);
      Properties connectionProps = new Properties();
                      connectionProps.setProperty("DSC_DEFAULT_SOAP_ENDPOINT", "http://
      hostname:8080");
                      connectionProps.setProperty("DSC_TRANSPORT_PROTOCOL","SOAP");
                      connectionProps.setProperty("DSC_SERVER_TYPE", "JBoss");
                      connectionProps.setProperty("DSC_CREDENTIAL_USERNAME", "username");
                      connectionProps.setProperty("DSC_CREDENTIAL_PASSWORD", "password");
                      //Create a ServiceClientFactory object
                      ServiceClientFactory myFactory =
      ServiceClientFactory.createInstance(connectionProps);
                      ResourceRepositoryClient repositoryClient = new
      ResourceRepositoryClient(myFactory);
                      // Create a RepositoryInfomodelFactoryBean needed for creating
      resources
                      RepositoryInfomodelFactoryBean repositoryInfomodelFactory = new
      RepositoryInfomodelFactoryBean(null);
                         // Create the resource to be written to the folder
                      /**     Resource testResource = repositoryInfomodelFactory.newResource(
                          new Id(),
                          new Lid(),
                          "testResource"
                      // Set the resource’s description
                      Resource testResource = new Resource();
                      testResource.setId(new Id());
                      testResource.setLid(new Lid());
                      testResource.setName("xyz.pdf");
                      testResource.setDescription("test resource");
                      ResourceContent testContent =
      repositoryInfomodelFactory.newResourceContent();
                      Document doc = new Document(iFile,false);
                      testContent.setDataDocument(doc);
                      testResource.setContent(testContent);
                         // Write the resource to the folder
                      repositoryClient.writeResource(LC_FOLDER_PATH, testResource);
                      // Retrieve the resource’s URI
                      String resourceUri = LC_FOLDER_PATH + "/" + testResource.getName();
                         // Retrieve the resource to verify that it was successfully
      written
                      Resource r = repositoryClient.readResource(resourceUri);
                      List<Resource> members =
      repositoryClient.listMembers(LC_FOLDER_PATH);
                      for(Resource r1:members) {
                              System.out.println("r1 name =" + r1.getName());
                         // Print the resource verification message
                      System.out.println("Resource " + r.getName() + " was successfully
      written.");
                      }catch(Exception ex){ex.printStackTrace();}
      Jyothi
