6 Replies Latest reply on Sep 14, 2011 12:34 AM by PihlDK
    Check user input
    mp-landbjorn
      Have this small script (my first attempt in Scripting), which is loaded with Acrobat 9 at startup.
      app.addMenuItem({ cName: "Gem &KMS-skrivelse", cParent: "File", cExec: "SaveAs('registreringsmeddelelse', 'produkter/')", nPos: 3 });
      app.addMenuItem({ cName: "Gem &dokument i sag", cParent: "File", cExec: "SaveAs('', '')", nPos: 4 });
      function SaveAs(cName, cDirectory)
          //Get full year
          var date=new Date();
          cYear = date.getFullYear();
          //Get year, case number and file name from user input
          var cYear = app.response({ cQuestion: "Indtast sagsår:", cTitle: "Sagsår", cDefault: cYear });
          var cCase = app.response({ cQuestion: "Indtast sagsnr.:", cTitle: "Sagsnr."});
          var cFile = app.response({ cQuestion: "Indtast filnavn (uden .pdf):", cTitle: "Filnavn", cDefault: cName });
          if (cFile == null)
               return;
          //Concatenate path string
          var cPath = "/h/digi/s" + cYear + "/" + cYear + "-" + cCase + "/" + cDirectory + cFile + ".pdf";
          //Try to save the document, if success, inform the user where to
          try {
              this.saveAs({ cPath: cPath, bPromptToOverwrite: true });
              app.alert("Dokumentet blev gemt i " + cPath, 3);
          catch(e) {
              app.alert("Kunne ikke gemme dokument i " + cPath + ". Kontroller at mappen er oprettet, og at du har skriverettigheder til denne, samt at Acrobat/Reader er sat korrekt op.");
          //So long and thanks for all the fish
          return;
      Based on user input it saves documents to folders on a network share.
      It  works just fine, but if the user cancel the input dialog, null is  returned, and eventually will be part of the filename. So I use a if  statement to check if cFile is null, and if true just returns the  function. But this fails with this error message:
      GeneralError: Handlingen mislykkedes.
      Root.(null):17:Menu Gem &dokument i sag:Exec
      script terminated
      Why is this so?
      Best regards
      mp
        • 1. Re: Check user input
          BarlaeDC Level 4
          if you changed your code a little it may be avoidable
          if (cFile != null)
              try {
              catch(e) {
          this should allow the code to complete as expected without saving the document if cFile is null.
          Hope this helps
          Malcolm
          • 2. Re: Check user input
            mp-landbjorn Level 1
            Thanks, Malcolm.
            But it still doesn't work. I don't know if it is my Acrobat installation that is unable to run the script, or I am doing it wrong (guess it's me).
            Look at this small script:
            app.addMenuItem({ cName: "Null Check", cParent: "File", cExec: "NullCheck()", nPos: 0 });
            function NullCheck()
                var cInput = app.response({ cQuestion: "Input something:", cTitle: "Random Input" });
                if (cInput == null)
                    return;
                return;
            If I input someting in the response dialog the script runs just fine, but if I cancel the response dialog I get this error message:
            Root.(null):8:Menu Null Check:Exec
            script terminated
            What am I doing wrong?
            Regards
            Martin
            • 3. Re: Check user input
              I'm getting the same behavior, but here's the really weird thing.
              Add this line just after the app.response line:
              app.alert(cInput);
              What do you know... No more errors being thrown.
              Take it out, the same thing happens again.
              I would say just ignore it, if possible...
              • 4. Re: Check user input
                Haha, you're right, try67. It is indeed weird!
                The user input is used as a filename, so if the user cancels the input and null is returned, the pdf is saved as "null.pdf". That's why I want to check the input, and just exit the function if the user cancels.
                • 5. Re: Check user input
                  PihlDK
                  The script still continues after return;
                  Try this
                      //Get full year
                     if (cFile == null)
                  else
                      try {
                      catch(e) {
                      return;
                  • 6. Re: Check user input
                    PihlDK Level 1
                    Or perhaps just
                        if (cFile != null)
                        try {
                        catch(e) {
                        return;
