6 Replies Latest reply on Sep 9, 2011 2:54 PM by rbsiv
    tips on deepening shadows in a clip?
    rbsiv Level 1
      I'm curious about the best combination of effects for deepening blacks and the other darkest areas of a clip whilst leaving the lighter areas relatively untouched. I have a bunch of material where the general brightness levels are perfect, save for washed-out 'blacks' that appear more dark gray at the moment. Any thoughts?
        • 1. Re: tips on deepening shadows in a clip?
          sacha_G
          The three-way color corrector can help you here as there are separate controls for Highlights/Midtones/Shadows
          - Just select the shadow option and you can adjust the input/output and gamma to suit. You can also adjust the range of dark to light that is affected in the shadow range:
          • 2. Re: tips on deepening shadows in a clip?
            ExactImage Level 3
            In addition to the Thrre-Way-Color you can also use the Luma curves effect (GPU accelerated as well).
            We would generally add Luma Curves to DSLR footage, as an exmaple.
            • 3. Re: tips on deepening shadows in a clip?
              Jim_Simon Level 8
              I'd probably just use the Fast Color Corrector and bring up the Input Level till the blacks reached 0 IRE.
              • 4. Re: tips on deepening shadows in a clip?
                Colin Brougham Level 6
                +1 on Luma Curves... or more specifically, +1 on RGB Curves. It does everything that Luma Curves does plus give you chroma control as well. That's convenient, since if you have to adjust the color of a shot (to a certain extent), you can do so with one effect rather than two or more. With CUDA acceleration, it's not too much of an issue, but my general feeling is that less is more whenever possible.
                • 5. Re: tips on deepening shadows in a clip?
                  sacha_G Level 1
                  Quoting Colin Brougham <forums@adobe.com>:
                  Interestingly (and I only just spotted this myself) there is a Luma
                  Correction plugin (CUDA) which does this too (CC without the color
                  section) - but you do need to bear in mind that the two plugins
                  (curves vs CC/LC) work in different ways and will give you different
                  results. Try both and use whichever looks best.
                  Another tip while you're at it - it's useful to have a waveform
                  monitor panel setup so you can see where your shadows are ending up
                  and not getting crushed out of existence.
                  • 6. Re: tips on deepening shadows in a clip?
                    rbsiv Level 1
                    Many thanks for all the suggestions. Been doing a little trial & error, looks like the Three Way CC will suit my purposes for these.
