9 Replies Latest reply: Sep 10, 2011 2:06 AM by olivier madar RSS
    Best workflow CS5 with RedOne and MacBook Pro
    olivier madar Community Member
      I am looking at the best workflow for the RedOne and my MacBookPro.
      1) Work with native R3D :
      Do the grade in RCX and save metadata
      Import in CS5
      Edit
      XML export to RCX again
      Grade again and save metadata
      Re-import metadata in Premiere timeline
      What is wrong with this workflow for me :
      - The MacBook Pro is not a workhorse (even its latest version i7) and no Cuda acceleration. You can read native R3D at 1/8 resolution, but there is a latency when you hit "play"
      - No way to re import all the metadata at once in timeline. I have to select all clip, then reload rmd individually
      - What else ?
      2) Off line editing
      Do the first grade in RCX and save metadata, export in ProRes 1024x576 (if 16/9)
      Import in CS5
      Edit
      Replace media by R3D in a new timeline just before master export in 2K or 1080p
      - Long time calculation
      - You have to select all the media and make them fit the new size
      - What else ?
