2 Replies Latest reply on Oct 22, 2006 4:10 AM by Newsgroup_User
    onRollover problems
    Carly G
      I'm creating a XML photogallery, and have created movieClips with the loaded jpg from the XML using createEmptyMovieClip. The problem is that onRollover doesn't work. Does the hit area not include the loaded jpg?
      Here's what I have
      slides_xml = new XML();
      slides_xml.onLoad = startSlideShow;
      slides_xml.load("photoGallery.xml");
      slides_xml.ignoreWhite = true;
      function startSlideShow(success) {
      if (success == true) {
      rootNode = slides_xml.firstChild;
      totalSlides = rootNode.childNodes.length;
      firstSlideNode = rootNode.firstChild;
      var i = 0;
      var xPos = 35;
      var yPos = 35;
      thisDepth = 100;
      var currentSlide = rootNode.firstChild;
      while (( i < totalSlides) && ( i < 10))
      var buttonName = "btn" + i;
      _root.createEmptyMovieClip(buttonName, thisDepth);
      _root[buttonName]._x = xPos;
      _root[buttonName]._y = yPos;
      _root[buttonName]._xscale = _root[buttonName]._yscale = 20;
      _root[buttonName].jpeg = currentSlide.attributes.jpegURL;
      _root[buttonName].picTitle = currentSlide.attributes.picTitle;
      _root[buttonName].loadMovie(_root[buttonName].jpeg);
      _root[buttonName].hitArea = mcHit;
      _root[buttonName].onRollOver = function ()
      _root.txtDescription.text = _root[buttonName].picTitle;
      currentSlide = currentSlide.nextSibling;
      yPos = yPos + 75;
      thisDepth = thisDepth + 1
      i++;
      if (yPos > 400)
      yPos = 40;
      xPos = xPos + 90;
        • 1. Re: onRollover problems
          you need to define mouse handlers AFTER loading is completed.
          • 2. Re: onRollover problems
            Level 7
            Loading anything into a movieclip overwrites all properties (except _x,
            _y and maybe a few others).
            The result, in your case, is that .jpeg, .picTitle .hitArea and
            .onRollOver is all gone when the image is finished loading.
            The easiest way out is to create a child movieclip and load the image
            into that.
            like this:
            var mcButton = _root.createEmptyMovieClip(buttonName, thisDepth);
            mcButton._x = xPos;
            mcButton._y = yPos;
            mcButton._xscale = _root[buttonName]._yscale = 20;
            mcButton.jpeg = currentSlide.attributes.jpegURL;
            mcButton.picTitle = currentSlide.attributes.picTitle;
            // create child movieclip:
            mcButton.mcImage = mcButton.createEmptyMovieClip("mcImage", 1);
            // and load image into that one:
            mcButton.mcImage.loadMovie(_root[buttonName].jpeg);
            mcButton.hitArea = mcHit;
            This way all only properties of mcButton.mcImage is overwritten :)
            - Magnus
            > Here's what I have
            > var i = 0;
            > var xPos = 35;
            > var yPos = 35;
            > thisDepth = 100;
            > yPos = yPos + 75;
            > i++;
            > if (yPos > 400)
            > yPos = 40;
            > xPos = xPos + 90;
