2 Replies Latest reply on Sep 12, 2011 12:22 PM by lithodora
    [CS4][AS] Can't Get Alias
    lithodora
      Prior to posting I searched these forums for a solution: Your search for "Alias" returned 0 results
      If someone can tell me what I am doing wrong I'd greatly appreciate it.
      I am trying to make a print publication from an online NFL picks contest we are running. I have set up AS to use JS to grab all the info and place it all in variables. Now I need to place the graphics into the table I have in InDesign. There are frames each with a script label that matches the variable in the AS
      I have tried to do this two ways and I get the same error: "InDesign can not get the alias SpecialSections:Special Pages A-G:Football Challenge 2011:1 Logos:Filename.pdf" (Filename.pdf is just what I put in there for an example)
      set theLogofolder to "Volumes/SpecialSections/Special Pages A-G/Football Challenge 2011/1 Logos/" --Has PDFs of every NFL team LOGO named ATL.pdf, GB.pdf, etc...
      --game1vip1 -> GB --because they picked Green Bay
      set theLogo to (game1vip1 as string) & ".pdf"
      set theImage to ((theLogofolder as string) & (theLogo as string) as alias)
      tell application "Adobe InDesign CS4"
      activate
      tell rectangle "game1vip1" of page 1 of document 1
      place theImage --Errors
      end tell
      end tell
      Note: Telling Acrobat to open theImage opens the image, so the file exists and the alias is a true reference to that file
      Next I try:
      tell application "System Events"
      set these_files to every file of folder theLogofolder
      end tell
      repeat with i from 1 to the count of these_files
      set this_file to (item i of these_files as alias)
      set this_info to info for this_file
      if visible of this_info is true and alias of this_info is false then
      if name of this_info contains game1vip1 then
      activate
      place this_file  --Errors
      end tell
      end tell
      end if
      end if
      end repeat
      Another thought I had to solve it was to rename the script labels (using the script) to the value.
      Something like:
          set label of rectangle "game1vip1" to game1vip1  --error
      end tell
      Doesn't work...
      A solution to this would be great.
      From here down is really a separate issue, but relates to the previous and could make the whole thing easier to deal with overall.
      Another issue is the way I set this up to begin with:
      set thislabel to label of every rectangle of page 1 of document 1
      end tell
      --> {"Game16VIP6", "Game15VIP6", "Game14VIP6", "Game13VIP6", "Game12VIP6", "Game11VIP6", "Game10VIP6", "Game9VIP6", "Game8VIP6", "Game7VIP6", "Game6VIP6", "Game5VIP6", "Game4VIP6", "Game3VIP6", "Game2VIP6", "Game1VIP6", "Game16VIP5", "Game15VIP5", "Game14VIP5", "Game13VIP5", "Game12VIP5", "Game11VIP5", "Game10VIP5", "Game9VIP5", "Game8VIP5", "Game7VIP5", "Game6VIP5", "Game5VIP5", "Game4VIP5", "Game3VIP5", "Game2VIP5", "Game1VIP5", "Game16VIP4", "Game15VIP4", "Game14VIP4", "Game13VIP4", "Game12VIP4", "Game11VIP4", "Game10VIP4", "Game9VIP4", "Game8VIP4", "Game7VIP4", "Game6VIP4", "Game5VIP4", "Game4VIP4", "Game3VIP4", "Game2VIP4", "Game1VIP4", "Game16VIP3", "Game15VIP3", "Game14VIP3", "Game13VIP3", "Game12VIP3", "Game11VIP3", "Game10VIP3", "Game9VIP3", "Game8VIP3", "Game7VIP3", "Game6VIP3", "Game5VIP3", "Game4VIP3", "Game3VIP3", "Game2VIP3", "Game1VIP3", "Game16VIP2", "Game15VIP2", "Game14VIP2", "Game13VIP2", "Game12VIP2", "Game11VIP2", "Game10VIP2", "Game9VIP2", "Game8VIP2", "Game7VIP2", "Game6VIP2", "Game5VIP2", "Game4VIP2", "Game3VIP2", "Game2VIP2", "Game1VIP2", "Game16VIP1", "Game15VIP1", "Game14VIP1", "Game13VIP1", "Game12VIP1", "Game11VIP1", "Game10VIP1", "Game9VIP1", "Game8VIP1", "Game7VIP1", "Game6VIP1", "Game5VIP1", "Game4VIP1", "Game3VIP1", "Game2VIP1", "Game1VIP1", "", "", "", "", "", "", "", "", "ad5", "ad4", "ad2", "ad3", "ad1", ""}
      For every label there is also a corresponding  variable in the AS....
      I REALLY need a way to cycle through the variables and nothing works...Dynamic variable names seems to be a dream in AS
      repeat with v from 1 to 2
      repeat with g from 1 to 2
      --set this_pick to "Game" & v & "VIP" & g
      set this_logo to "game" & v & "vip" & g
      set this_logo to value of this_logo
      end repeat
      end repeat
      Any help on any of my issues would be greatly appreciated
        • 1. Re: [CS4][AS] Can't Get Alias
          Muppet Mark Level 5
          You have 2 completely differing methods here… 1. is concating strings (no guarantee a file exists)… 2. get files this will always return alias files or nothing… If you want to go the first route then you could…
          set Logos_Folder to (path to desktop as text) & "Some Junk:" -- A sting variable
          set Logo_Name to "GB" -- Another sting variable
          try
          set This_Logo to (Logos_Folder & Logo_Name & ".pdf") as alias -- Concat the strings then coerce
          -- If an 'alias' was made then the file exists
          my placeFile(Logo_Name, This_Logo)
          on error
          display dialog "Hum… The File Does Not Exist…?" giving up after 3
          end try
          -- Pass your name string & file alias
          on placeFile(Logo_Name, This_Logo)
          tell application "Adobe InDesign CS5"
          activate
          tell document 1
          tell page 1
          tell (the first rectangle whose label is Logo_Name)
          place This_Logo
          end tell
          end tell
          end tell
          end tell
          end placeFile
          This example is just for the one file but you just need to add loop and pass the sub 2 properties for each instance…
          • 2. Re: [CS4][AS] Can't Get Alias
            lithodora Level 1
            A little change, but pretty much what you provided worked.
            set theLogofolder to "SpecialSections:Special Pages A-G:Football Challenge 2011:1 Logos:"
            set This_Label to "game1vip1"
            try
            set This_Logo to (theLogofolder & Logo_Name & ".pdf") --as alias -- Concat the strings then coerce
            my placeFile(This_Label, This_Logo)
            on error
            end try
            on placeFile(This_Label, This_Logo)
            activate
            tell document 1
            tell page 1
            tell (the first rectangle whose label is This_Label)
            place This_Logo
            fit given proportionally
            fit given center content
            end tell
            end tell
            end tell
            end tell
            end placeFile
