0 Replies Latest reply on Sep 10, 2011 6:24 AM by Butch2oc
    XMP data issue with mixed up audio
    Butch2oc Level 1
      I have a lot of xdcam (+similar) footage in a rather large project.
      We move the project around a fair bit to different systems/editors etc.
      A couple of times we have had audio in some of the footage all muddled up. Not in sync at all, in fact as if
      a time displacement effect has been placed on the audio. Really weird!
      I sorted through the forum and found others had the issue and a fix was to delete all the cache files.
      This did not work for me and after alot of trial and error I found that if I deleted the .xmp file associated with the media and then reopened project and relinked
      all was fine, back to the way it was.
      As a precaution to not have to check all cut programs each time we change systems I'm thinking of deleting all .xmp files associated with the media each time as a precaution.
      My question is this:
      If I turn off "Write XMP ID to files on import" will this solve my problem? Why is this function needed?
      Would I turn off "Enable Clip and XMP Metadata Linking aswell?
      Basically my project is huge and important, I can't afford to have a corrupt .xmp file placing egg on my face.
      Thanks in advance
