2 Replies Latest reply on Sep 12, 2011 7:01 PM by Adam-C
    Sound latency in Director 11.5
    bd525
      My project utilizes brief (< 1 second) sound files in close succession. Sound latency (delay between files) must be very low, and all versions of Director from 6 through MX 2004 have provided excellent performance. Now that I've "upgraded" to 11.5 I find that latency has increased to unacceptable levels. Does anybody know what has changed and what--if any--solutions exist?
      Bruce
      Mac PowerBook 2.26 GHz Core 2 Duo
      4 GB Ram
      Director 11.5
      OS 10.7.1 (Lion)
      quickTimeVersion(): 7.7062
      the soundDevice: "CoreAudio"
        • 1. Re: Sound latency in Director 11.5
          Necromanthus Level 2
          Talking about Director Shockwave and sound latency, the order is the following:
          MacroMix > QT3Mix > DirectSound
          So if you set _sound.soundDevice = "DirectSound", you'll get the best latency (1-2ms).
          Of course, you'll need a decent sound card (Creative Audigy for example).
          The main problem is that DirectSound is available on Windows only.
          cheers
          • 2. Re: Sound latency in Director 11.5
            Adam-C Level 2
            I'd embed a Flash object to handle the audio playback - if you are able to either embed the sound files into the SWF or preload them prior to use then you should get pretty-much instant response when calling each sound.
