3 Replies Latest reply on Sep 21, 2011 10:36 PM by daslicht
    populating MX:Tree with Directory Structure using PHP
    daslicht Level 2
      Hello,
      I have written the following php function to return the directory structure :
           public function get_dir_iterative()
                $dir = 'data';
                $exclude = array( 'cgi-bin', '.', '..' );
                $folders = '<?xml version="1.0"?>';
                $folders .= "<node label='Root' path=\"data\">";
                //$folders .= $this->getFolderRecuring("data");
                $exclude = array_flip($exclude);
                $dh = opendir($dir);
                //$stack = array($dh);
                //$level = 0;
                          //closedir(array_shift($stack));
                while(count($stack))
                     if(false !== ( $file = readdir( $stack[0] ) ) )
                          if(!isset($exclude[$file]))
                               if(is_dir($dir . '/' . $file))
                                    $dh = opendir($dir . '/' . $file);
                                    if($dh)
                                         $folders .= "<node label=\"$file\" path=\"$dir/\" isBranch=\"true\" />";
                                         array_unshift($stack, $dh);
                                         ++$level;
                               else
                                    $folders .= "<node label=\"$file\" path=\"$dir/\">";
                     else
                          --$level;
                $folders .= "</node>";
                return $folders;
      When I test this function manually it returns the proper structure.
      But when I call it with help of ZendAMF there is nothing returned and the sandclock is spinning infinite ?!
      here is the flex part:
      private var fms:RemoteObject = new RemoteObject();
      protected function initFileManagerService():void
           fms.destination ='zend';
           fms.source='FileManagerService';
           fms.showBusyCursor=true;
           fms.addEventListener( FaultEvent.FAULT, faultListener);
           fms.get_dir_iterative.addEventListener( ResultEvent.RESULT, load_result );
           trace('FileManagerService initialized');
      public function load():void
           fms.get_dir_iterative();
           trace('Service / load');
           private function load_result( e:ResultEvent ):void
                trace('result:'+e.result)
      My zend setup is working, any idea what could be wrong ?
