5 Replies Latest reply on Sep 12, 2011 8:53 AM by Ned Murphy
    centerTF
    Ron Colmen Level 2
      I'm creating a TextField. How do I center it to a perticular movieclip (ab_mc).
      createTF(_root.ab_mc._x+_root.ab_mc._width/2,_root.ab_mc._y+_root.ab_mc._height/2,""); //this doesn't work though!
      Message was edited by: Ron Colmen
        • 1. Re: centerTF
          You determine the width of the mc and the width of the textfield and use the _x property of the mc to determine where to place the _x property of the textfield.  The _x property of the textfield should be...
          tf._x = mc._x + ((mc._width - tf._width)/2);
          (assuming the mc registration is to its left side)
          • 2. Re: centerTF
            Ron Colmen Level 2
            not sure why? didn't work.
            newTF.onRelease=function(){
            createTF(_root.ab_mc._x + ((root.ab_mc._width - root.ab_mc.new_mc.tf._width)/2));
            }//this piece of code is in another movieclip
            Also how do I add the ._y property here?
            • 3. Re: centerTF
              I have no idea what your createTF function does, so I cannot tell why it won't.
              • 4. Re: centerTF
                Ron Colmen Level 2
                var tl:MovieClip = this;
                function createTF(x:Number,y:Number,s:String):Void{
                var tf_mc:MovieClip = tl.attachMovie("tfID1.tf_mc_"+textNum++,tl.getNextHighestDepth());
                • 5. Re: centerTF
                  Your function doesn't appear to make use of any of the parameters you are passing to it, nor even to create a textfield.  It seems like you can't get something working because you haven't done anything to get it working.  Try looking up the createTextField method in the Flash help documentation if you want to see how to create a textfield dynamically and how to place it where you want it to be.
