3 Replies Latest reply on Jul 16, 2015 7:36 AM by lindsays13896292
    Why I can't render m2ts files in Adobe premiere elements 9
      I'm new working with adobe. I have a Sony Handycam HDR-CX700V. I am able to import the footage into the timeline, but am not able to render. The red line doesn't apear anywhere. When I choose render work area, the adio tracks and the vidio layers just move up and down as if am scrolling, and plays for abut a second and stops without rendering anything. The resolution of compoent on the camera is set at 1080i/480i. However, I try other video formats such as VOB and the red line is there and I'm able to render, but those videos were captured with an older model camera. My system consist of an Intel(R) PENTIUM (R) CPU 2.80GHZ 2.79 GHZ Memory (RAM) 5.00 GB System type: 32-bit Operationg System and it's a Windows Vista. Somebody pleas help me
        • 1. Re: Why I can't render m2ts files in Adobe premiere elements 9
          Your camcorder shoots in a number of video and audio formats, so it's important first to determine which format you're shooting in. (You say it's shooting in 1080i/480i, but that's actually two very different formats!) If you plan to edit your video in Premiere Elements, it's important that you shoot only in either 1920x1080 at 60i or 1440x1080 at 60i. Do not shoot 1920x1080 in 24p or 60p or you're going to have problems! The 720x480 AVC will also likely give your trouble.
          Once you've determined which format you're shooting in, it's important to ensure that the project settings you select when you set up your project match this video format! If you don't select, for instance, AVCHD settings for AVCHD footage, these components will not automatically activate for the program.
          The biggest issue, however, is that your computer is way underpowered for working with hi-def video. In my books, I even recommend a dual-core computer for working with standard definition video. For working with AVCHD, I recommend an i7 or quad core processor. Trying to edit AVCHD on a Pentium will pretty much slow your system to a crawl if it works at all. Sorry.
          Although you may be able to work with very short videos, if you've got plenty of free hard drive space (I'd recommend 50 gigabytes, at least), your project is set up to match your source video and you don't mind a lot of system lag.
          • 2. Re: Why I can't render m2ts files in Adobe premiere elements 9
            camerani1 Level 1
            Thank you Steve, I really appreciate that. For I just change the setting on the camera. I7 Processor will need to wait
            • 3. Re: Why I can't render m2ts files in Adobe premiere elements 9
              What did you change your record setting to on your camera?
