1. Re: Rounding prices
Manan Joshi Sep 12, 2011 11:46 PM (in response to Jaime de Vos)You could use the following script
var inputNo = "€ 11.812,50"
var PIndex = inputNo.indexOf(".")
var roundOffNo = inputNo.substring(0, PIndex + 1) + Math.round(inputNo.replace(",", ".").substring(PIndex + 1))
where "inputNo" is your original number and "roundOffNo" is the result.
Hope this solves your problem
Manan Joshi
- Efficient InDesign Solutions -
MetaDesign Solutions
http://metadesignsolutions.com/services/indesign-development.php
2. Re: Rounding prices
Laubender Sep 13, 2011 5:44 AM (in response to Manan Joshi)Manan,
I wonder what will happen to a input like: € 999.999,50 ?
We would get € 1000.000 instead of € 1.000.000 .So I would suggest a function that first strips out every dot and after rounding adds the sufficient number of dots like that:
function _roundPrice(foundString){ var _Array = new Array(); //Strip every dot from the string: var _string = foundString.replace(/\./g,"").replace(/,/g,"."); //Strip the € sign from the array and round the number: var _newString = Math.round(_string.replace(/€\s/,"")).toString(); //Push every single character to the array: for(var n=0;n<_newString.length;n++){ _Array.push(_newString.charAt(n)); }; //Insert dots every 3 characters from end: for(var n=_Array.length-4;n>=0;n=n-3){ _Array[n] = _Array[n]+"."; }; //Add the € sign plus a blank: return "€ "+_Array.join(""); };Now, as we have that function we need a method to search/replace the prices in the document.
If the prices strictly are formatted with a character style one can do it with the following code (given the applied character style is named "Price"):var _d=app.activeDocument; //Reset the Text search input field: app.changeTextPreferences = app.findTextPreferences = null; //Find all text applied with the character style named "Price": app.findTextPreferences.appliedCharacterStyle = "Price"; //Built array of the found texts: var _foundText = _d.findText(); //IMPORTANT: Loop from back to forth: for(var n=_foundText.length-1;n>=0;n--){ //Set the contents of the found texts to the returned strings of the function _roundPrice: _foundText[n].contents = _roundPrice(_foundText[n].contents); }; //Reset the Text search input field: app.changeTextPreferences = app.findTextPreferences = null;BUT SEE THIS WARNING: if a single white space around the price is erroneously formatted with "Price" the function will not work right.
Another method could be a GREP search, though I'm not sure exactly what the right expression will be to get all possible instances of the prices like:
€ 1.000.000.000,56 (multiple dots)
€ 197,56 (no dots at all)
One expression would be:
€\\s+\\d+\\.?\\d+\\.?\\d+,?\\d+
which neglects cases without dots and is limited to maximum two dots:var _d=app.activeDocument; app.changeGrepPreferences = app.findGrepPreferences = null; app.findGrepPreferences.findWhat = "€\\s+\\d+\\.?\\d+\\.?\\d+,?\\d+"; var _foundText = _d.findGrep(); for(var n=_foundText.length-1;n>=0;n--){ _foundText[n].contents = _roundPrice(_foundText[n].contents); }; app.changeGrepPreferences = app.findGrepPreferences = null;So, maybe it's up to the original poster to come up with a better expression or doing two search/replace scripts with a slightly altered GREP.
Uwe
3. Re: Rounding prices
Manan Joshi Sep 13, 2011 11:35 PM (in response to Laubender)Laubender,
My code had one glicth, also i had written it on the suppostion that the input no will have only one dot and one comma the question also intends this i think.
So my corrected code would be
var inputNo = "999.999,50"
var Cindex = inputNo.indexOf(",")
var len = inputNo.substring(PIndex + 1, Cindex).length;
var lenAfterRounding = String(Math.round(inputNo.replace(",", ".").substring(PIndex + 1))).length;
var roundOffNo;
if(lenAfterRounding > len)
roundOffNo = inputNo.substring(0, PIndex ) * 1 + 1;
else
In this snippet i have handled the situation when the input no is something like 999.999,50 where rounding off would also effect the number before the decimal.
I have added 1 to the number before decimal in case the rounding of the number after decimal causes a carry over.
Manan Joshi
4. Re: Rounding prices
Laubender Sep 14, 2011 12:56 AM (in response to Manan Joshi)Manan,
thank you for your new code.
However, if I take your example of:var inputNo = "999.999,50";
I will get a result by:
$.writeln(roundOffNo);
in the console of the ESTK of:
1000
and not of
1.000.000
Everything goes right for numbers in the range of 0,00 to 999,49.
Uwe
5. Re: Rounding prices
Manan Joshi Sep 14, 2011 1:09 AM (in response to Laubender)Ok, i thought the user was using a custom number format in which we could have only a single point and comma. I was not aware of the numbering system using . and , together. I suppose . here is used to seperate thousands and , as a decimal point. If this is the case then my code won't work as pointed out by you correctly.
I apolozise for the misunderstanding.
Manan Joshi
www.metadesignsolutions.com
6. Re: Rounding prices
Jaime de Vos Sep 14, 2011 1:13 AM (in response to Manan Joshi)Thanks everyone, for the massive amounts of response.
I'm going to give all those scripts a go and let you know the results.
7. Re: Rounding prices
Jaime de Vos Sep 14, 2011 1:46 AM (in response to Jaime de Vos)function _roundrechtslijnend(foundString){
//Find all text applied with the character style named "rechtslijnend":
app.findTextPreferences.appliedCharacterStyle = "rechtslijnend";
//Set the contents of the found texts to the returned strings of the function _roundrechtslijnend:
_foundText[n].contents = _roundrechtslijnend(_foundText[n].contents);
app.changeTextPreferences = app.findTextPreferences = null;This script works. Infact, in my tests it even adds Euro signs to prices that did not have any yet! The only thing that might cause a problem for the sales people, is that it rounds both up and down. I think that they, them being sales guys, might opt for the round up only version.
Can that be specified with? (going out on a limb here);
Math.roundUP
8. Re: Rounding prices
pkahrel Sep 14, 2011 2:00 AM (in response to Laubender)This function rounds up numbers with decimal commas and dots for thousands separators:
function roundPrice (num)
// Remove thousand separators
num = num.replace (/\./g, "");
// Replace decimal comma with a dot
num = num.replace (/,(?=\d\d$)/, ".");// Round the number up to the nearest integer
num = Math.round (Number (num));// Restore thousand separators
num = String(num).replace(/(\d)(?=(\d\d\d)+$)/g, "$1.");
return num;
}Uwe -- I think this grep finds numbers following Euro symbols:
(?<=€\s)[.\d]+,\d\d
Your expression allows some flexibility in the number of spaces between the Euro symbol and the first digit, but on the other hand, you could say that a finished text should have just one space there. And with the lookbehind you match just the number, which makes processing the money amounts a bit easier.
Peter
9. Re: Rounding prices
Jaime de Vos Sep 14, 2011 2:33 AM (in response to pkahrel)Not a single double space in the document, thanks to the wonders of Grep.
Thanks, I will try this out. -
10. Re: Rounding prices
Laubender Sep 14, 2011 5:24 AM (in response to Jaime de Vos)@Peter:
Thank you for commenting!
And, of course, your roundPrice() function.@Jaime:
it could have been another white space character like an En Dash, a Tab or something:
\s does find them all.So try it out and let us know how it works…
Uwe
11. Re: Rounding prices
Jaime de Vos Sep 14, 2011 7:57 AM (in response to Laubender)Thank you, Peter.
Lau, Peter;
Struggling to combine both scripts. It now looks like this;
function roundPrice (num) { // Remove thousand separators num = num.replace (/\./g, ""); // Replace decimal comma with a dot num = num.replace (/,(?=\d\d$)/, "."); // Round the number up to the nearest integer num = Math.round (Number (num)); // Restore thousand separators num = String(num).replace(/(\d)(?=(\d\d\d)+$)/g, "$1."); return num; } var _d=app.activeDocument; //Reset the Text search input field: app.changeTextPreferences = app.findTextPreferences = null; //Find all text applied with the character style named "Price": app.findTextPreferences.appliedCharacterStyle = "Price"; //Built array of the found texts: var _foundText = _d.findText(); //IMPORTANT: Loop from back to forth: for(var n=_foundText.length-1;n>=0;n--){ //Set the contents of the found texts to the returned strings of the function _roundPrice: _foundText[n].contents = _roundPrice(_foundText[n].contents); }; //Reset the Text search input field: app.changeTextPreferences = app.findTextPreferences = null;Yet it generates the following error. I'm confident that your scripting works and that the error lies with my implementation.
(fictional prices)
12. Re: Rounding prices
pkahrel Sep 14, 2011 8:39 AM (in response to Jaime de Vos)You need to change two things:
1. The function's name is roundPrice but you call it as _roundPrice.
2. Use a GREP search, not a Text search:app.findGrepPreferences = null;
app.findGrepPreferences.findWhat = "(?<=€\\s)[.\\d]+,\\d\\d";and change other occurrences of findText with findGrep
Peter
13. Re: Rounding prices
Hm, in that case he will not find instances where the "€ " is missing…
He'd better search a second time for the applied character style using a GREP and adding the € plus the blank to the found strings where needed.
Uwe -
14. Re: Rounding prices
pkahrel Sep 14, 2011 1:13 PM (in response to Laubender)You're quite right. I hadn't realised that the prices are in a character style.
Peter
15. Re: Rounding prices
[Jongware] Sep 14, 2011 2:42 PM (in response to Jaime de Vos)Jaime de Vos wrote:
[..] The only thing that might cause a problem for the sales people, is that it rounds both up and down. I think that they, them being sales guys, might opt for the round up only version.
Math.roundUPOnly FYI ('cause you seem to be enjoying this newly discovered "scripting" ):
number ceil (x: number)
Rounds the number up to the nearest integer.Parameter Type Description x number A number. Example Math.ceil(x) number floor (x: number)
Rounds a number down to the nearest integer.Parameter Type Description x number A number. Example Math.floor(x) Warning:
ceil will always round up, even for the tiniest fraction above a whole number!
x = 1.000000001; alert (Math.ceil(x));
16. Re: Rounding prices
pkahrel Sep 15, 2011 2:25 AM (in response to [Jongware])And Math.round(n) rounds up from .5 (3.5 > 4) down up to .5 (3.49 > 3).
17. Re: Rounding prices
Jaime de Vos Sep 15, 2011 3:17 AM (in response to Jaime de Vos)Will take some time for me to digest all the new input. Need to wrap my head around the concept some more. Compare it to following a discussion that's partly spoken in a different language. But I'm confident I can condense the proposed changes into a working script.
Thanks again.
