3 Replies Latest reply on Sep 19, 2011 1:00 PM by mckeyes2
    Inserting data into MySql
    mckeyes2
      Hi all, I'm using FlashBuilder 4.5 to develop a web app. Followed all the tutorials and samples I could find for this. Basically a user goes through a few screens and selects options from drop downs and enters a few numbers in. At the end they are presented with their results. I would like to take all the values they entered and insert them into a database using PHP.
      I used the Connect to PHP option and everything configured correctly. Using the test feature, I can get the inserts to work. When running the app in debug mode it steps through all the lines and finishes without error but nothing gets inserted into the database. I followed the samples on Adobe's site and everything appears to be similar but I cannot figure out why it's not working.
      Application section:
      xmlns:riskresultsservice="services.riskresultsservice.*"
      Service call: createRiskResultsResult.token = riskResultsService.createRiskResults(riskResults);
      <fx:Declaration section I have
      <valueObjects:RiskResults id="riskResults" />
      <s:CallResponder id="createRiskResultsResult"/>
      <riskresultsservice:RiskResultsService id="riskResultsService"
         fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)"
         showBusyCursor="true"/>
      I then have a function that sets all the values for riskResults
      example:
      riskResults.age = risk_age;
      riskResults.height = risk_height;
      I set a watch for riskResults and I can see the values being set.
      Please help
        • 1. Re: Inserting data into MySql
          mckeyes2 Level 1
          I found where the hangup is but have no idea how to go about correcting. Following through in debug mode, I get to the AbstractServices.as file to the initialize function on line 375.
          public function initialize():void
               if (!_initialized && _managers != null)
                    for (var i:int = 0; i < _managers.length; i++)
                         var mgr:Object = _managers[i];
                         if (mgr.hasOwnProperty("initialize"))
                              mgr.initialize();
                    _initialized = true;
          it get's hung up on the mgr.initialize() statement. I get a "Source not found." with a button to Edit Source Lookup Path...
          I have no idea where to look for the source path. Is this a problem with the Flex SDK (4.5.1)?
          • 2. Re: Inserting data into MySql
            daslicht Level 2
            When calling: riskResultsService.createRiskResults(riskResults) Do you get a Error displayed ?
            Where/How are you handling the result for 'riskResultsService'?
            After setting :
            you have to call the service to write the actual changes:
            If you would post a bit more complete code we could maybe better help you
            • 3. Re: Inserting data into MySql
              mckeyes2 Level 1
              Thank you for the response. I hope I have enough info here. Most of the code here is auto generated within Flash Builder. All I really did was add the values into the insertItem valueObject and call the service handler. I don't need a vaue returned back to the application since all this is doing is recording values into a MySQL db. If I run this normally, it will run fine but nothing gets sent to the db. If i go through the debugger, it steps into the core files and fails while trying to initialize the service. Every exmple I find online has this implemented slightly differently so I'm not quite sure what's going on.
              <s:Application ...
                        xmlns:riskresultservice="services.riskresultsservice.*"
              <fx:Script>
                   import services.riskresultsservice.RiskResultsService;
                   import valueObjects.RiskResults;
                   private function createInsertArrayItems():void
                        insertItem.age = riskAge;
                        insertItem.actvity = activity;
                        insertItem.height = riskHeight;
                   protected function btnNext_clickHandler(event:MouseEvent):void
                        // some of code
                        createInsertArrayItems();
                        createRiskResults(insertItem);
                        // some more code
                   protected function createRiskResults(item:RiskResults):void
                        createRiskResultsResult.token = riskResultsService.createRiskResults(item);
              </fx:Script>
              <fx:Declarations>
                   <valueObjects:RiskResults id="insertItem" />
                   <s:CallResponder id="createRiskResultsResult" />
                        fault="Alert.show(event.fault.faultString + '/n' + event.fault.faultDefault)"
                        showBusyCursor="true" />
              </fx:Declarations>
              <s:BorderContainer>
              </s:BorderContainer>
              </s:Application>
