1 Reply Latest reply on Oct 24, 2006 10:31 AM by Newsgroup_User
    Developing Dynamic Sound Objects
    WebXperience Level 1
      I am creating dynamic Sound objects using the info returned from a
      for (var i in _root) evaluation.
      I have structured the name of the variable in the following code. How can I cast that [name] as a Sound Object then have it point to or load an mp3 on the server?: In other languages you can do this with a pointer. But as there are no pointers in ActionScript, is there a workaround?
      Attach Code
      j=0;
      for (var i in _root) {
      if (typeof (eval(i)) == "movieclip") {
      var name:String = i + "Sound"; // I want to use the contents of this "name " variable to create a new Sound Object which will be popluated from an XML attribute which contains the Sound URL
      var [name]:Sound = new Sound(); // This doesn't work
      sClip= eval(i);
      sClip.songTitle.text = songs[j++].attributes.desc; // songs is an array populated from an XML file.
      trace(sClip + " \n Next Line: " + name + sClip.songTitle.text);
        • 1. Re: Developing Dynamic Sound Objects
          Level 7
          WebXperience,
          In ActionScript 2.0, strong typing is *only* checked at compile time.
          It's just a convenience for light error checking, and is not actually
          adhered to in the bytecode. So in this case, you can skip it.
          The closest I got was this ...
          this[name] = new Sound();
          ... which neither answers your question nore adheres to recommended best
          practice, but what you're after is somehow "outside the box," so to speak.
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
