1. Re: UI - How to make Columns in a Drop Down List Selection?
Harbs. Sep 12, 2011 10:44 PM (in response to RichardM0701)Unless Marc Autret has some ingenious way of faking it, I think you are out of luck using Script UI.
You can probably create a multi-column dropdown in a Flash UI, but even there, it's non-trivial...
Harbs
2. Re: UI - How to make Columns in a Drop Down List Selection?
pkahrel Sep 14, 2011 2:21 AM (in response to RichardM0701)Richard,
Interesting problem! As Harbs said, you can't do this with a columned list, because that's really a single column list in which each row has tab-separated items. That creates only the impression of columns. What you want is real columns and I think that you can do that by placing four lists next to each other. Something along these lines:
var w = new Window ("dialog");
var table = w.add ("group");
var col1 = table.add ("listbox");
var col2 = table.add ("listbox");
var col3 = table.add ("listbox");
var col4 = table.add ("listbox");
w.show();This creates four separate lists, but you can fiddle with the margins to create the impression of a single table.
Peter
3. Re: UI - How to make Columns in a Drop Down List Selection?
Harbs. Sep 14, 2011 2:29 AM (in response to RichardM0701)He. I just looked at the screen shot.
It's not as complicated as I thought you were talking about.
Your best bet is to use a Flash UI using a Datagrid.
Harbs
4. Re: UI - How to make Columns in a Drop Down List Selection?
RichardM0701 Sep 14, 2011 2:26 PM (in response to pkahrel)Hi Peter,
This is one of those developments that push the limits of my knowledge-base and when things do that, I lose sleep until I figure it out. With that said :-) here is where I have ended up.
Basically I made a new array for the table data. I then use an array lookup to sort the array in the listbox based on the 0 array item. See the code below. Once it is loaded type in "b" and the list will start to sort.
I need to try to get this to work as a pallete instead of a dialog box. Do palletes support this type of functionality?
var newarray = new Array( new Array('Butterfly ','has wings','can fly'), new Array('bohemith moth','has wings','cannot fly very good'), new Array('word 3','replacement word','use case')); picked = type_ahead (newarray); function type_ahead (array) { var w = new Window ("dialog", "STE Checker"); var entry = w.add ("edittext", [0, 0, 800, 22]); entry.active = true; var list = w.add ("listbox", [0, 0,800, 500], "", {numberOfColumns: 3, showHeaders: true, columnTitles: ["Column 1", "Column 2", "Column 3" ], columnWidths: [200,200,400]}); list.selection = 0; entry.onChanging = function () { var temp = this.text; list.removeAll (); for (var i = 0; i < array.length; i++) if (array[i][0].toLowerCase().indexOf (temp) == 0) with (list.add ("item", array[i][0])) { subItems[0].text = array[i][1]; subItems[1].text = array[i][2]; } if (list.items.length > 0) list.selection = 0; } entry.onChange = function () {} if (w.show () != 2) return list.selection.text; else w.close (); } -
5. Re: UI - How to make Columns in a Drop Down List Selection?
pkahrel Sep 15, 2011 2:42 AM (in response to RichardM0701)Yes, you can do this as a palette, but you need to change two things.
1. Target an engine. At the beginning of the script, add this:
#targetengine "session";
2. You can't use this code:
if (w.show () != 2)
else
w.close ();Instead use simply w.show(). You then need to add a control which, when clicked, determines what you want to do. For example, add a button "Stop" and a handler along these lines:
stopButton.onClick = function ()
// do this
// update that
w.close();
Peter
6. Re: UI - How to make Columns in a Drop Down List Selection?
RichardM0701 Sep 16, 2011 7:17 AM (in response to pkahrel)Thanks a ton! Works like a charm.
