1 2 Previous Next 48 Replies Latest reply: Nov 1, 2011 4:13 PM by Todd_Kopriva RSS
    Adobe Premiere Pro CS5.5 (5.5.1) update
    Sheri Codiana Community Member
      Hi all,
      The Adobe Premiere Pro CS5.5.1 update is now live on Adobe.com:
      http://www.adobe.com/support/downloads/product.jsp?product=98&platform=Macintosh
      http://www.adobe.com/support/downloads/product.jsp?product=98&platform=Windows
      The readme will be posted shortly, and expect the AAM updater to come out in the next week or two. Here's the summary from the readme:
      The Adobe Premiere Pro CS5 5.5.1 update fixes issues that were discovered when using Adobe Premiere Pro with Mac OS X 10.7 (Lion). The update also fixes an issue where XML project files created in Premiere Pro don’t work with DaVinci Resolve.
      • MAC: Fixed an issue in Mac OS X 10.7 where the Universal Counting Leader is missing countdown numbers
      • MAC: Fixed an issue where Adobe Premiere Pro would crash upon quitting when running on Mac OS X 10.7
      • WINDOWS: Fixed an issue where the Preview was not functioning properly in the capture panel for HDV
      • Fixed an issue where imported Final Cut Pro XML projects that contain multiple mono clips will lose some audio when project is closed and reopened
      • Fixed an issue where exporting to DVCPRO HD 720p60 QuickTime does not complete with graphic, image or synthetic in the sequence
      • Fixed an issue where a clip is repositioned when a CUDA Invert is applied to the clip
      • Fixed a crash in Adobe Premiere Pro when viewing sequence clip in source monitor
      • Improved scrubbing performance with Canon DSLR files
      • Fixed an issue where Adobe Premiere Pro could not find files after changing location of project
      • Fixed an issue where Adobe Premiere Pro would randomly crash on startup
      • Fixed an issue After Effects comp with a background other than black would result in no alpha transparency when Mercury Playback GPU Acceleration was enabled
      • Fixed an crash in Adobe Premiere Pro if you create a new sequence from After Effects, you had the sequence presets tab in focus and no sequence preset selected
      • Fixed an issue where Adobe MXF files are not readable by Sony XDCAM HD Deck, Final Cut Pro nor Media Composer
      • Fixed an issue where Adobe Premiere Pro’s commit size increases when closed captioning is enabled
      • Fixed an import failure with ProRes files created by ATOMOS with 4 tracks of audio
      • Fixed an issue where MCC files exported from MacCaption with a FrameRate set to 50 or 59.94 fails to display in Adobe Premiere Pro’s Program Monitor when attached to sequences that match their frame rate
      • Fixed a display failure with NVIDIA driver 275.36
      • Fixed a problem with incorrect data written to XML files for AVCIntra exports
      • Fixed an issue when a AVCIntra sequence with an adjust start times exports it has an unsupported string in the “StartTimeCode” tag in the XML
      • Fixed an issue when the Mercury Playback Engine GPU Acceleration enabled, opacity effects are being ignored after second transition
      • Fixed a hang or a crash in Adobe Premiere Pro when loading a merged clip with disabled audio channels
      • Fixed an issue where media from Avid Unity QuickTime reference files are not imported
      • Fixed an issue where XML project files created by Adobe Premiere Pro do not work with DaVinci’s Resolve
      • Fixed an issue where image sequences lose their frame rates
      • Fixed an issue where when adding a transition the edges of the clip are highlighted during the transition
        1 2 Previous Next
