5 Replies Latest reply on Dec 11, 2006 8:45 AM by Graeme Harker
    An internal build error has occurred.
    Graeme Harker Level 1
      java.lang.NullPointerException
      at macromedia.asc.semantics.ConstantEvaluator.evaluate(ConstantEvaluator.java:934)
      at macromedia.asc.parser.LiteralNumberNode.evaluate(LiteralNumberNode.java:29)
      at macromedia.asc.semantics.ConstantEvaluator.evaluate(ConstantEvaluator.java:993)
      at macromedia.asc.parser.LiteralFieldNode.evaluate(LiteralFieldNode.java:29)
      at macromedia.asc.semantics.ConstantEvaluator.evaluate(ConstantEvaluator.java:1800)
      at macromedia.asc.parser.ArgumentListNode.evaluate(ArgumentListNode.java:28)
      at macromedia.asc.semantics.ConstantEvaluator.evaluate(ConstantEvaluator.java:971)
      at macromedia.asc.parser.LiteralObjectNode.evaluate(LiteralObjectNode.java:26)
      at macromedia.asc.semantics.ConstantEvaluator.evaluate(ConstantEvaluator.java:1829)
      at macromedia.asc.parser.ListNode.evaluate(ListNode.java:27)
      at macromedia.asc.semantics.ConstantEvaluator.evaluate(ConstantEvaluator.java:2125)
      at macromedia.asc.parser.ReturnStatementNode.evaluate(ReturnStatementNode.java:27)
      at macromedia.asc.semantics.ConstantEvaluator.evaluate(ConstantEvaluator.java:1906)
      at macromedia.asc.parser.StatementListNode.evaluate(StatementListNode.java:36)
      at macromedia.asc.semantics.ConstantEvaluator.evaluate(ConstantEvaluator.java:2412)
      at macromedia.asc.parser.FunctionCommonNode.evaluate(FunctionCommonNode.java:87)
      at macromedia.asc.semantics.ConstantEvaluator.evaluate(ConstantEvaluator.java:2427)
      at macromedia.asc.semantics.ConstantEvaluator.evaluate(ConstantEvaluator.java:3124)
      at macromedia.asc.parser.ClassDefinitionNode.evaluate(ClassDefinitionNode.java:86)
      at macromedia.asc.semantics.ConstantEvaluator.evaluate(ConstantEvaluator.java:2863)
      at macromedia.asc.parser.ProgramNode.evaluate(ProgramNode.java:63)
      at flex2.compiler.as3.Compiler.analyze4(Compiler.java:547)
      at flex2.compiler.mxml.ImplementationCompiler.analyze4(ImplementationCompiler.java:232)
      at flex2.compiler.mxml.Compiler.analyze4(Compiler.java:126)
        • 1. Re: An internal build error has occurred.
          mac_martine Level 1
          This has been logged and fixed internally, so this will be fixed in the next release. Thank you!
          • 2. Re: An internal build error has occurred.
            I just started getting a similar error. Is there any timeline on when the next release will be out?
            • 3. Re: An internal build error has occurred.
              FYI The workaround I'm using is to create a brand new Flex project and "import" the original project's contents into the new project (with the exception of the ..settings, bin and html-template folders) and rebuild. This always fixes the problem (also proving it's not an issue with the source code of the applicaiton itself). If you find a more convenient workaround, let me know.
              • 4. Re: An internal build error has occurred.
                Level 1
                sparky - thanks for the quick reply. I've tried that (and everything else I can think of), but it doesn't help me. My error isn't exactly the same as yours, so I'll post it below in case anybody else has any ideas. Thanks.
                This is the error from the Flex Builder log:
                !ENTRY com.adobe.flexbuilder.project 4 43 2006-09-14 11:57:32.698
                !MESSAGE Uncaught exception in compiler
                !STACK 0
                java.lang.NumberFormatException: multiple points
                at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:1084)
                at java.lang.Double.valueOf(Double.java:447)
                at macromedia.asc.embedding.avmplus.ActionBlockEmitter.getValueOfNumberLiteral(ActionBlockEm itter.java:1273)
                at macromedia.asc.semantics.ConstantEvaluator.evaluate(ConstantEvaluator.java:2218)
                at macromedia.asc.parser.VariableBindingNode.evaluate(VariableBindingNode.java:48)
                at macromedia.asc.semantics.ConstantEvaluator.evaluate(ConstantEvaluator.java:2174)
                at macromedia.asc.parser.VariableDefinitionNode.evaluate(VariableDefinitionNode.java:32)
                at macromedia.asc.semantics.ConstantEvaluator.evaluate(ConstantEvaluator.java:3071)
                at flex2.compiler.API.analyze(API.java:2128)
                at flex2.compiler.API.analyze(API.java:2041)
                at flex2.compiler.API.batch2(API.java:319)
                at flex2.compiler.API.batch(API.java:901)
                at flex2.compiler.API.compile(API.java:1110)
                at flex2.compiler.API.compile(API.java:1022)
                at com.adobe.flexbuilder.project.compiler.Compiler.compile(Unknown Source)
                at com.adobe.flexbuilder.project.compiler.internal.FlexIncrementalBuilder.buildApplication(U nknown Source)
                at com.adobe.flexbuilder.project.compiler.internal.FlexIncrementalBuilder.build(Unknown Source)
                at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:593)
                at org.eclipse.core.internal.runtime.InternalPlatform.run(InternalPlatform.java:1044)
                at org.eclipse.core.runtime.Platform.run(Platform.java:783)
                at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:168)
                at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:202)
                at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:231)
                at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:234)
                at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:253)
                at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:282)
                at org.eclipse.core.internal.resources.Workspace.build(Workspace.java:211)
                at org.eclipse.ui.actions.GlobalBuildAction$1.run(GlobalBuildAction.java:182)
                at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
                • 5. Re: An internal build error has occurred.
                  I've just discovered a new workaround for this (very common) problem - if you do a Project -> Clean... to rebuild the whole project you bypass Eclipse's "incremental builder" which appears to be causing the problem. This probably deserves to be whatever the equivalent of a KB is on planet Adobe
