4 Replies Latest reply on Sep 14, 2011 1:29 AM by jazz_matazz
    Detect direct P2P connection attempts
    jazz_matazz
      Hello,
      I wonder if it exits a way to detect P2P connection attempts in a DIRECT_CONNECTIONS scenario. NetStream::onPeerConnect allows to accept (or not accept) P2P direct connection, but it's raised on connection successful. But nothing allows to detect the beginning of attempts.
      I presume that the rendez-vous service sends initiator peer informations to destinator peer, to reach the UDP hole punching process. It we were able to detect initiator peer id who trying to connect us (on target peer side), we could fall back on server more easily!
      You confirm that it's not available, no event allows it?
      Best regards,
      Mathieu
        • 1. Re: Detect direct P2P connection attempts
          Michael Thornburgh Adobe Employee
          there is no event for the case you're talking about.
          until the RTMFP session is open, the target doesn't know the peer ID of the peer attempting the connection (the Initiator Hello packets only have the destination peer ID).
          until the subscribing peer sends the 'play("streamname")' command down a NetStream control flow on an open RTMFP session, the target doesn't know if the connection was for groups or DIRECT_CONNECTIONS (or both, since both can be multiplexed on the same RTMFP session).
          for more detail on how RTMFP works and why it is the way it is, take a look at Matthew Kaufman's slides from his presentation on RTMFP at IETF 77:
             http://www.ietf.org/proceedings/10mar/slides/tsvarea-1.pdf
          -mike
          • 2. Re: Detect direct P2P connection attempts
            jazz_matazz Level 1
            But I don't understand, during "UDP hole punching process", rendez-vous service sends to target peer the initiator peer id (and address), it's forced, no? So the peer target could know that a P2P connection is trying.
            In the AS3 code we don't know it, yes, however it could be a improvement, because these information is available no? I am wrong?
            Indeed, if both peers know that they are trying to etablish one P2P connection between them, they could create a "server bridge" while the P2P connection is attempting (not successfull).
            • 3. Re: Detect direct P2P connection attempts
              no. the rendezvous service doesn't send the peer ID of the initiator to the target.
              your application logic can inform the target that a connection is incoming through an out-of-band communication channel if you write it that way. for example, the "VideoPhoneLabs" example on the Cirrus Labs web page uses Cirrus's "short message relay service" to send a call notification to the target.
              Jozsef recently posted to another thread in this forum a short code snippet that can be used with FMS to duplicate that relay function.
              • 4. Re: Detect direct P2P connection attempts
                jazz_matazz Level 1
                Ok, and really thanks for this details :-)
