• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Sourceless Deploy Doesn't Work On Linux!
New Here ,
Aug 16, 2006 Aug 16, 2006
Hello all....
I cfcompiled an app in windows. The compiled files run great under windows.
I deploy those same files to a linux server running CFMX7 Enterprise, and the app won't run. I keep getting "unexpected constant" errors on every file. If I replace a file that caused an unexpected constant error with a non-compiled version, the app moves on the the next compiled file and thows another error. So, it's definitely the compiled files that are causing these errors.
What do I do now?
Thank you for your help.
tom
TOPICS
Advanced techniques
Views
456
Translate
Translate
Report
Report
Community guidelines
community guidelines
Enthusiast ,
Aug 17, 2006 Aug 17, 2006
I just tested this starting on a winXP system/CFMX 7.01. I moved the compiled files to a Suse9/CFMX7.01 environment and they run fine. I am using the default JRE installed by CFMX on both machines. I do note the linux machine has the case-sensitivity issues you would expect. So, when I am trying to invoke a local webservice I must match the path exactly.
What is your linux environment and are you running the same JRE in both environments. Compiling under a newer JVM then what is used for running has often produced bad results for me.
Votes
Translate
Translate
Report
Report
New Here ,
Right now, I am just trying to get one stand-alone precompiled template to run, and I still get those unexpected constant errors. So, filename case problems are not an issue yet.
I cfompliled on this machine:
Server Product ColdFusion MX
Version 7,0,1,116466
Edition Enterprise (DevNet)
Operating System Windows 2003
OS Version 5.2
Java Version 1.4.2_05
Java Vendor Sun Microsystems Inc.
Java Vendor URL http://java.sun.com/
Java Home C:\CFusionMX7\runtime\jre
Java File Encoding Cp1252
Java Default Locale en_US
File Separator \
Path Separator ;
Line Separator Chr(13)
Java VM Specification Version 1.0
Java VM Specification Vendor Sun Microsystems Inc.
Java VM Specification Name Java Virtual Machine Specification
Java VM Version 1.4.2_05-b04
Java VM Vendor Sun Microsystems Inc.
Java VM Name Java HotSpot(TM) Server VM
Java Specification Version 1.4
Java Specification Vendor Sun Microsystems Inc.
Java Specification Name Java Platform API Specification
Java Class Version 48.0
Here is the target machine:
Edition Enterprise
Operating System UNIX
OS Version 2.6.9-22.ELsmp
JVM Details
Java Version 1.4.2_06
Java Home /CFusionMX7/jdk/jre
Java File Encoding UTF8
File Separator /
Path Separator :
Line Separator Chr(10)
Java VM Version 1.4.2_06-b03
Could the differences in line separator and file encoding be causing this problem?
Thanks again.
tom
Votes
Translate
Translate
Report
Report
Enthusiast ,
Aug 21, 2006 Aug 21, 2006
Try using the built in JRE on you linux environment. Next try cfcompile on you linux environment.
What is the linux/unix environment. Since this is environment specific, knowing the specifics would help.
Votes
Translate
Translate
Report
Report
Enthusiast ,
I tested again using the 1.4.2_06 JRE on a RHES4 linux box. It worked there also.
I do note that my kernel build is 2.6.9-34.
Votes
Translate
Translate
Report
Report
New Here ,
Aug 22, 2006 Aug 22, 2006
Ken, thanks for your help on this.
I don't have access to the target server, so I can't cfcompile there.
Would you mind checking your PC and RHES4 server to see if there are any differences between your configurations and mine? (shown above)
I'm still wondering if this is a CF or JVM version issue. Or maybe the differences in the java file encoding or line seperator.
-tom
Votes
Translate
Translate
Report
Report
Guest
Jan 02, 2007 Jan 02, 2007
LATEST
I don't believe this is a linux specific issue. I'm experiencing something similar. I've compiled the code (for sourceless deployment) on my development machine (running XP, with CF7 developers edition). I've run the compiled code on my company's staging servers just fine, but have run into the same error described on a client's server (I don't have access to the specifications, but I do know they run entirely on windows boxes). If I can come up with any more information I'll post in here, in hopes that it may help lead to an answer
Votes
Translate
Translate
Report
Report
Resources
Documentation
