2 Replies Latest reply on Oct 21, 2011 12:06 AM by Mrsunilg
    Building WebServiceSettingBean
    Mrsunilg Level 1
      Please let me know how do i build WebServiceSettingBean Variable using setValue activity.
      When i use setValue acitivity i see following details as metioned in image below
      I know wsdl only which is as follow : http://HYDHTC137429d:8080/EForm/services/EmailCollectorService?wsdl
      using this url i am able to generate following values like
      1. Usr Name/password
      2. port
      3. Target Url
      4. operation
      5. wsdl content
      6. soap request
      When i use setValue, i see under webservicevariable ->object and many parameters.
      Please let me know/correct me the varibles type that i need to set
      1. attachment (for me its not required)
      2. Uthenticatepremptive (nor required)
      3. Input Request ( how do i pass input request, what is the variable type of it. This service is taking two string type variable, then how do i set it??)
      4. What is the datatype of following variables (operationName, password, port,target url, username, wsdl etc)
      thanks in advance
        • 1. Re: Building WebServiceSettingBean
          $Nith$ Level 4
          1. attachments (optional) - data type is Map of documents; You may leave this is there is no attachments need to be passed as arguments to the web service
          2. AuthenticatePreemptively (optional) - This is a boolean value; default is false() - You need not set this value unless the invoke operation need to send authentication headers before calling the web method.
          3. InputRequest (mandatory) - data type is org.w3c.dom.document. Or you may also supply an XML String will be converted internally.
          Hope that helps.
          • 2. Re: Building WebServiceSettingBean
            Mrsunilg Level 1
            Thanks for replying.. but I need some more clarity on third point.
            Do you mean the request xml which is generted in wsdl??
            if i am correct then how to i change input vairables in xml document dynamically??
