This content has been marked as final.
Show 2 replies
1. Re: Is it possible to use the mask from one image in other images?
MTSTUNER Sep 14, 2011 11:52 AM (in response to SF Ellen)If the images are exactly the same size then make sure the layer with the mask
is the active layer and in the other documents go to Select>Load Selection and choose
your document with the layer mask under Source document and under channel choose the layer mask.
After the selection loads press the layer mask icon at the bottom of the layers panel.
MTSTUNER
2. Re: Is it possible to use the mask from one image in other images?
SF Ellen Sep 14, 2011 1:45 PM (in response to MTSTUNER)You are a genius!!! That worked like a charm.
Thank you so much!
