3 Replies Latest reply on Sep 19, 2011 1:59 PM by Haakenlid
    How to adjust a table imported from Word to InDesign
    tony.veld
      Hi all,
      I am new to InDesign scripting. The problem I have is that I have hundreds of Word 2003 files which I need to import into InDesign CS5. The basics are under control excepting the tables. They import OK but then I need to change the cell padding, the style and the alignment of each table. There are lots per file.
      I found a script "TableStyle.js" which adjusts the cell padding for all tables in an InDesign file (extract from the file below). What I don't know is how to change the entire table (or perhaps it is the enclosing paragraph) to Normal style and centred alignment.
      Can anybody help
      // Processing of tables
      function myTableMaker() {
            try{var myTablesCount = mySelect.tables.length;}
            catch(err){var myTablesCount = 1;}
            for (myCounter = 0; myCounter < myTablesCount; myCounter++) {
                  try{
                        var myTable = mySelect.tables.item(myCounter);
                  catch(err){
                        var myTable = mySelect;
                  // Setting spaces above and below
                  myTable.spaceBefore = mySpaceBeforeSave + myUnits;
                  myTable.spaceAfter = mySpaceAfterSave + myUnits;
      // Change table justification to Centre Justified
      // Change table style to Normal
        • 1. Re: How to adjust a table imported from Word to InDesign
          John Hawkinson Level 5
          Hi Tony:
          Assuming you in fact mean the paragraph styles of all the contents of all the cells, rather than a table style then:
          myTable.cells.everyItem().texts.everyItem().appliedParagraphStyle="Normal";
          I'm not quite sure what you mean by "centered alignment." Why not do that in the paragraph style? Anyhow:
          myTable.cells.everyItem().texts.everyItem().justification=Justification.CENTER_JUSTIFIED;
          • 2. Re: How to adjust a table imported from Word to InDesign
            tony.veld Level 1
            Hi John,
            Thanks for your answer. I am not talking about the content of the cells in the table.
            I am talking about the entire table. When I do it manually I click the cursor to the left of the table and there is a flashing vertical bar, the full height of the table on the left edge of the table. Then when I click the centre justify button then the entire table moves to the centre of the page.
            The same of the normal style - I want to apply the style to the table not the cells inside the table.
            • 3. Re: How to adjust a table imported from Word to InDesign
              Haakenlid Level 3
              Use storyOffset to find the insertionpoint where the table is anchored. That's where you can make it centered or whatever.
              myTable.storyOffset.appliedParagraphStyle = "Normal";
              myTable.storyOffset.justification = Justification.CENTER_ALIGN;
