I have a corporate version of CS5.5 installed on 32bit machine.
Recently, Flash Builder notified me of an available update. It was for some Java but since Eclipse is Java Based I intalled it.
Now when I open it, it freezes on the splash screen. Without closing it, I open a new one. It asks for a new workspace since old used, I gave it new one. Still stuck on splash screen. Tried restarting computer. Now when I open Flash Builder, it is not stuck on splash page but and error popups and program exits. The popup tells me to look at a log file.
Here is the log file contents
!SESSION 2011-09-15 11:03:52.113 ----------------------------------------------- eclipse.buildId=M20110210-1200 java.version=1.6.0_16 java.vendor=Sun Microsystems Inc. BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US Command-line arguments: -os win32 -ws win32 -arch x86 !ENTRY org.eclipse.osgi 4 0 2011-09-15 11:03:53.844 !MESSAGE Application error !STACK 1 org.eclipse.swt.SWTError: No more handles at org.eclipse.swt.SWT.error(SWT.java:4109) at org.eclipse.swt.SWT.error(SWT.java:3998) at org.eclipse.swt.SWT.error(SWT.java:3969) at org.eclipse.swt.widgets.Widget.error(Widget.java:468) at org.eclipse.swt.widgets.Control.createHandle(Control.java:633) at org.eclipse.swt.widgets.Composite.createHandle(Composite.java:305) at org.eclipse.swt.widgets.Control.createWidget(Control.java:649) at org.eclipse.swt.widgets.Scrollable.createWidget(Scrollable.java:134) at org.eclipse.swt.widgets.Control.<init>(Control.java:110) at org.eclipse.swt.widgets.Scrollable.<init>(Scrollable.java:75) at org.eclipse.swt.widgets.Composite.<init>(Composite.java:95) at org.eclipse.ui.splash.BasicSplashHandler.getBundleProgressMonitor(BasicSplashHandler.java:159) at org.eclipse.ui.splash.BasicSplashHandler.getContent(BasicSplashHandler.java:265) at org.eclipse.ui.internal.splash.EclipseSplashHandler.init(EclipseSplashHandler.java:86) at org.eclipse.ui.internal.Workbench$8.run(Workbench.java:782) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at org.eclipse.ui.internal.Workbench.createSplashWrapper(Workbench.java:798) at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2467) at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438) at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149) at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashBuilderApplication.java:108) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574) at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
Edit - found another thread with similar issue but still no solution.
I'm getting the same problem, have you heard of or found a fix for this issue yet?
I am in the same boat now and OH SO HOSED. Help, Adobe!
Hi
Just did a update in FB4.6 and now have above issue.
Any word on this.
Cheers
Yes, same here. I just upgraded to FB4.6 and now am having this problem. A solution would be great to see.
Hello, I'm having the same issue with Flash Builder 4.6.
I got it off freeriatools.adobe.com, after installing I tried to open it and it said "An unexpected runtime error occured : No more handles" with the following errors in the log file :
!SESSION 2012-04-25 20:40:19.812 -----------------------------------------------
eclipse.buildId=I20100608-0911
!ENTRY org.eclipse.ui 2 0 2012-04-25 20:40:36.702
!MESSAGE Warnings while parsing the commands from the 'org.eclipse.ui.commands' and 'org.eclipse.ui.actionDefinitions' extension points.
!SUBENTRY 1 org.eclipse.ui 2 0 2012-04-25 20:40:36.702
!MESSAGE Commands should really have a category: plug-in='com.qnx.flashbuilder.multiplatform.qnx.ui', id='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.OpenInfoCenter', categoryId='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.category.help'
!ENTRY org.eclipse.osgi 4 0 2012-04-25 20:40:37.412
!MESSAGE An unexpected runtime error has occurred.
!STACK 0
at org.eclipse.swt.SWT.error(SWT.java:4308)
at org.eclipse.swt.SWT.error(SWT.java:4197)
at org.eclipse.swt.SWT.error(SWT.java:4168)
at org.eclipse.swt.widgets.TaskBar.createHandle(TaskBar.java:103)
at org.eclipse.swt.widgets.TaskBar.<init>(TaskBar.java:96)
at org.eclipse.swt.widgets.Display.getSystemTaskBar(Display.java:2564)
at org.eclipse.ui.internal.Workbench$TaskBarDelegatingProgressMontior.getTaskItem(Workbench.java:303)
at org.eclipse.ui.internal.Workbench$TaskBarDelegatingProgressMontior.handleTaskBarProgressUpdated(Workbench.java:319)
at org.eclipse.ui.internal.Workbench$TaskBarDelegatingProgressMontior.worked(Workbench.java:268)
at org.eclipse.ui.internal.Workbench$StartupProgressBundleListener.bundleChanged(Workbench.java:420)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:847)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEventPrivileged(Framework.java:1522)
at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1458)
at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1453)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:391)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:462)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(Unknown Source)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
at org.eclipse.equinox.internal.ds.model.ServiceComponent.createInstance(ServiceComponent.java:480)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.createInstance(ServiceComponentProp.java:271)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:332)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:588)
at org.eclipse.equinox.internal.ds.ServiceReg.getService(ServiceReg.java:53)
at org.eclipse.osgi.internal.serviceregistry.ServiceUse$1.run(ServiceUse.java:138)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.internal.serviceregistry.ServiceUse.getService(ServiceUse.java:136)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:468)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:467)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.getService(BundleContextImpl.java:594)
at org.osgi.util.tracker.ServiceTracker.addingService(ServiceTracker.java:450)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:980)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:1)
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:262)
at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:185)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:348)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:283)
at org.eclipse.core.internal.runtime.InternalPlatform.getBundleGroupProviders(InternalPlatform.java:225)
at org.eclipse.core.runtime.Platform.getBundleGroupProviders(Platform.java:1261)
at org.eclipse.ui.internal.ide.IDEWorkbenchPlugin.getFeatureInfos(IDEWorkbenchPlugin.java:291)
at org.eclipse.ui.internal.ide.WorkbenchActionBuilder.makeFeatureDependentActions(WorkbenchActionBuilder.java:1217)
at org.eclipse.ui.internal.ide.WorkbenchActionBuilder.makeActions(WorkbenchActionBuilder.java:1026)
at org.eclipse.ui.application.ActionBarAdvisor.fillActionBars(ActionBarAdvisor.java:147)
at org.eclipse.ui.internal.ide.WorkbenchActionBuilder.fillActionBars(WorkbenchActionBuilder.java:341)
at org.eclipse.ui.internal.WorkbenchWindow.fillActionBars(WorkbenchWindow.java:3564)
at org.eclipse.ui.internal.WorkbenchWindow.<init>(WorkbenchWindow.java:419)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.createWorkbenchWindow(Workbench3xImplementation.java:31)
at org.eclipse.ui.internal.Workbench.newWorkbenchWindow(Workbench.java:1920)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:1918)
at org.eclipse.ui.internal.Workbench$21.runWithException(Workbench.java:1202)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1595)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
!ENTRY org.eclipse.ui.workbench 4 0 2012-04-25 20:40:38.511
!MESSAGE FrameworkEvent ERROR
!STACK 0
!ENTRY org.eclipse.osgi 4 0 2012-04-25 20:40:38.974
!STACK 1
at org.eclipse.ui.internal.WorkbenchWindow.createProgressIndicator(WorkbenchWindow.java:3362)
at org.eclipse.ui.internal.WorkbenchWindow.createDefaultContents(WorkbenchWindow.java:1130)
at org.eclipse.ui.internal.WorkbenchWindowConfigurer.createDefaultContents(WorkbenchWindowConfigurer.java:623)
at org.eclipse.ui.application.WorkbenchWindowAdvisor.createWindowContents(WorkbenchWindowAdvisor.java:300)
at org.eclipse.ui.internal.WorkbenchWindow.createContents(WorkbenchWindow.java:1036)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.ui.internal.Workbench$22.runWithException(Workbench.java:1211)
I was wondering if anyone has found a solution to this problem yet? Because I need this software to work on my laptop in order to start working on my school projects.. Thanks in advance.
