3 Replies Latest reply on Jan 29, 2008 7:55 AM by eklux
    Problem in flex with cross-domain scripting using GET method
    eklux
      I have a strange problem in Flex, calling scripts located at other servers, using the GET method.
      When I want to connect with a HTTPService in Flex, to a script located on another domain than the flex application, I place a crossdomain.xml at the root of the script-server:
      <?xml version="1.0"?>
      <!-- http://www.script-domain.com/crossdomain.xml -->
      <cross-domain-policy>
      <allow-access-from domain="www.app-domain.com"/>
      </cross-domain-policy>
      The problem is that when using the GET method to the cross-script, it seemes that the flashplayer append the lookup for the crossdomain.xml at the end of the querystring. With an url snooper I can se the url requested, and when the player looks for the crossdomain.xml, it does it in a strange way:
      http://www.script-domain.com?var1=val1&var2=val2/crossdomain.xml
      It seems to use the url+querystring as url, and puts crossdomain.xml in the end of the querystring, which is NOT the location of it, and the app fails with a runtime error message.
      The lookup for the crossdomain.xml should look like this:
      If i use the POST method instead, it works fine, but I would like to be able to use the GET method as well.
      Any suggestions??
      /Jesper
