0 Replies Latest reply on Sep 15, 2011 1:28 PM by mm81bg
    InDesign PDF pull data to/from database
    mm81bg
      Hello, InDesign Gurus, all the respect to you helpers for your time...
         ...so here's my issue...I have ID files from which I need to create a PDF containing interactive fields which will be recognizable by Itext.I need to be able to extract data (text and images) from them manipulate that data evantually and may be put it back in those fields through the use of Itext.Any suggestions are welcome...including the use of photoshop or other software if needed but there are files already created in InDesign so I was hoping to find a solution with ID itself...thanks again for your help!!!
