15 Replies Latest reply on Sep 22, 2011 9:52 AM by kglad
    Creating Objects Class
    McbainGames11 Level 2
      Hey,
      I need some help with this code it makes and error when i put it into my project but when its in a blank project it works fine?
      code:
      package
          import flash.display.MovieClip;
          public class newchars extends MovieClip
              public function newchars()
                              for (var i:int = 0; i < 1; i++)
                      var newchar1:MovieClip = new mychar();
                      addChild(newchar1);
                      newchar1.x = Math.random() * 500;
                      newchar1.x = Math.random()*(stage.stageWidth - newchar1.width);
                      newchar1.y =  Math.random()*(stage.stageHeight - newchar1.height);
      error:
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
          at newchars()
          at IceMountain_fla::MainTimeline/frame2()
          at flash.display::MovieClip/gotoAndPlay()
          at IceMountain_fla::MainTimeline/fl_MouseClickHandler_2()
      as soon as i click my play button on the start menu it interfieres with my class!
      but in a blank project it works fine :S
      Class's can make some unusual errors lol
      Thanks.
        • 1. Re: Creating Objects Class
          smitchell94 Level 2
          Personally i would not do this "var newchar1:MovieClip = new mychar();"
          I would do this: var character:MyCharacter = new MyCharacter;
          • 2. Re: Creating Objects Class
            1.  is the newchars class a document class?
            if not,  that's the problem.  you're not waiting until newchars() has been added to the display list when you try and access the stage.  to remedy, use the addedtostage event.
            2.  is mychar the class of a movieclip in your document's library?
            if not, that's a problem.
            • 3. Re: Creating Objects Class
              Problem is number 1
              What if i needed to add more than one document class? Because there is only room for one as i see in the program!
              • 4. Re: Creating Objects Class
                error:
                #1046:Type was not found or was not a compile-constant: MouseEvent.
                #1046:Type was not found or was not a compile-constant: Event.
                code lines 6 and 7:
                Play_1.addEventListener(MouseEvent.CLICK, fl_MouseClickHandler_2);
                function fl_MouseClickHandler_2(event:MouseEvent):void
                    gotoAndPlay(2);
                • 5. Re: Creating Objects Class
                  if it's not a document class, use:
                  code:
                  package
                  import flash.events.Event;
                  this.addEventListener(Event.ADDED_TO_STAGE,init);
                  private function init(e:Event):void{
                                  addChild(newchar1);
                  • 6. Re: Creating Objects Class
                    I made it a document class but got those nouse event errors from frame 1 that i posted in the previous post , why could that be?
                    • 7. Re: Creating Objects Class
                      because you're using mouseevents in that or a linked class.
                      • 8. Re: Creating Objects Class
                        I am using my mouseevent in frame 1 to navigate to frame 2 from the actions layer, how is this bad? :S
                        • 9. Re: Creating Objects Class
                          it's not an issue of bad or good.  you asked a question and i answered it.
                          you started this thread asking a different quesiton and i answered it.
                          • 10. Re: Creating Objects Class
                            I appreciate help but i followed what you said about document class now it comes with mouseevent error and i am wondering why the error occurs when everything else is good? The mouse event has nothing to do with the class but it still has an error!
                            • 11. Re: Creating Objects Class
                              if you haven't changed newchars class since your original post or you used the code i suggested, you wouldn't see that error.
                              if you think you're doing one or the other above, you should create a new directory, save your fla to that directory and save your document class file to that directory.  then retest.
                              • 12. Re: Creating Objects Class
                                I have been doing your code now this is all the code now please tell me my error it is weird and i cannot work it out
                                Frame 1:
                                stop();
                                Play_1.addEventListener(Event.ENTER_FRAME, fl_MouseClickHandler_2);
                                function fl_MouseClickHandler_2(event:Event):void
                                    gotoAndPlay(2);
                                Frame 2:
                                stop();
                                var enemy1:newchars = new newchars();
                                addEventListener(Event.ENTER_FRAME, fl_EnterFrameHandler);
                                function fl_EnterFrameHandler(event:Event):void
                                    Bird_1.x = mouseX;
                                newchars class:
                                package
                                            this.addEventListener(Event.ADDED_TO_STAGE, addtostage);
                                        private function addtostage(e:Event):void
                                            for (var i:int = 0; i < 10; i++)
                                                addChild(newchar1);
                                                newchar1.y = 28.35;
                                This doesn't have a document class used in settings because i am using add to stage event as you said
                                Now please look over all the code in my .fla and tell me why i get this error:
                                Error: Error #2136: The SWF file file:///C|/Users/Brendon%20Battye/Desktop/Ice%20Mountain/Ice%20Mountain.swf contains invalid data.
                                    at newchars/frame2()
                                    at newchars/fl_MouseClickHandler_2()
                                • 13. Re: Creating Objects Class
                                  use:
                                  Frame 1:
                                  stop();
                                      gotoAndStop(2);
                                  Frame 2:
                                  stop();
                                  addChilld(enemy1);
                                      Bird_1.x = mouseX;  // assuming Bird_1 is on-stage
                                  • 14. Re: Creating Objects Class
                                    Yay!
                                    Omfg i cannot believe i would not see this LOL i feel really bad now you gave me right answer and even i knew everything seemed to be ok with the class but i tested heaps of diffrent ways before this thread and must of got it mixed up
                                    THANKYOU FOR THIS HAHA
                                    • 15. Re: Creating Objects Class
                                      you're welcome.
