29 Replies Latest reply on Sep 22, 2011 8:12 AM by melas076
    image and text change when sublink clicked
    melas076
      Dear,
      I would like to know how can i appear an image when i clicked on sublink?
      I have 3 MCs: sub_bg, ImgMc and bg.
      the code's sub_bg is :
      function linkF(s:String):Void
        _root.bg.txt.htmlText = s;
      the code's bg is:
      stop();
      var styles = new TextField.StyleSheet();
      styles.load("css/main.css");
      _root.bg.txt.html = true;
      _root.bg.txt.styleSheet = styles;
      _root.sub_bg.subTXT.html = true;
      _root.sub_bg.subTXT.styleSheet = styles;
      var newsXML:XML = new XML();
      newsXML.ignoreWhite = true;
      newsXML.onLoad = function(success) {
              if (success) {
      var defaultp:String =  newsXML.childNodes[0].childNodes[1].childNodes[0].firstChild.nodeValue;
      _root.bg.txt.text = defaultp;
          for(var i:Number=0;i<newsXML.firstChild.childNodes[1].childNodes.length;i++){
      var tlink:String = newsXML.childNodes[0].childNodes[1].attributes.Name;
      var linkS:String = newsXML.childNodes[0].childNodes[1].childNodes[i].attributes.name;
      var imageS:String = newsXML.childNodes[0].childNodes[1].childNodes[i].attributes.ImgUrl;
      var textS:String = newsXML.childNodes[0].childNodes[1].childNodes[i].childNodes;
      _root.sub_bg.subTXT.htmlText += "<a href='asfunction:linkF,"+textS+"'>"+linkS+"</a><br>";
      _root.sub_bg.linktitle.htmlText = tlink;
      newsXML.load("xml/homes.xml");
      I will appreciate your help.
      regards,
      MELAS
      Message was edited by: melas076
        • 1. Re: image and text change when sublink clicked
          where's linkF()?
          • 2. Re: image and text change when sublink clicked
            melas076 Level 1
            in sub_bg MC..... i tried this :
              _root.ImgMC.loadMovie(imageS);
            and in bg MC :
            _root.sub_bg.subTXT.htmlText += "<a href='asfunction:linkF,"+textS+","+imageS+"'>"+linkS+"</a><br>";
            but not working;
            any help plz!!!!
            Regards,
            MELAS
            • 3. Re: image and text change when sublink clicked
              it needs to be on the same timeline as the code below...
              stop();
              • 4. Re: image and text change when sublink clicked
                melas076 Level 1
                it worked but just load one picture and also when i click on submenu it doesn't change the image with text
                any help!
                Regards,
                MELAS
                • 5. Re: image and text change when sublink clicked
                  melas076 Level 1
                  i tried this code :
                  _root.ImgMC.loadMovie(''+imageS+'');
                  unfornately it doesn't works still
                  any suggestion or help please!!!!
                  regards,
                  MELAS
                  • 6. Re: image and text change when sublink clicked
                    the only thing you're doing is displaying textS.  you're not doing anything with imageS in linkF()
                    p.s.  please mark helpfull/correct responses.
                    • 7. Re: image and text change when sublink clicked
                      melas076 Level 1
                      dear Kglad,
                      I did helpfull/correct responses on your last post.
                      but I need to show image in ImgMC and Text in bg MC when i clicked on sublink.... i tried several time but i didn't find ....
                      _root.sub_bg.subTXT.htmlText += "<a href='asfunction:linkF,"+textS+", "+imageS+"'>"+linkS+"</a><br>";
                      _root.ImgMC.loadMovie(+imageS+);
                      any help!!!
                      regards,
                      MELAS
                      • 8. Re: image and text change when sublink clicked
                        use:
                        function linkF(s:String,s2:String):Void
                        _root.ImgMC.loadMovie(s2');
                        stop();
                                if (success) {
                        var defaultp:String =  newsXML.childNodes[0].childNodes[1].childNodes[0].firstChild.nodeValu e;
                        • 9. Re: image and text change when sublink clicked
                          melas076 Level 1
                          thanks so much Klad!!!!!
                          • 10. Re: image and text change when sublink clicked
                            you're welcome.
                            • 11. Re: image and text change when sublink clicked
                              melas076 Level 1
                              i tested your code but don't worked...
                              it showed me in _root.bg.txt.htmlText the s and s2 texts
                              and nothing in ImgMC also i added trace() to see the s2 but nothing....
                                _root.ImgMC.loadMovie(s2);
                                trace(s2);
                              it gives me "undefined".
                              why?
                              • 12. Re: image and text change when sublink clicked
                                because you're not using:
                                or newsXML.childNodes[0].childNodes[1].childNodes[i].attributes.ImgUrl is undefined in your for-loop.  use the trace() to debug if it's the later.
                                • 13. Re: image and text change when sublink clicked
                                  melas076 Level 1
                                  i swear i added and nothing want to work!!!!
                                  see my code:
                                  stop();
                                          if (success) {
                                  when i put _root.ImgMC.loadMovie(imageS);  with this code, it works well...
                                  any help!!!
                                  regards,
                                  MELAS
                                  • 14. Re: image and text change when sublink clicked
                                    where's linkF()??
                                    again, use:
                                    stop();
                                            if (success) {
                                    if that fails, use the trace() function in your for-loop and in linkF()
                                    • 15. Re: image and text change when sublink clicked
                                      melas076 Level 1
                                      i did it and not working yet
                                      see my code:
                                      in sub_bg:
                                        //trace(s2);
                                      in bg:
                                      stop();
                                              if (success) {
                                      //_root.ImgMC.loadMovie(imageS);
                                      //trace(imageS);
                                      it writes in _root.bg.txt.text like in image attached.
                                      in sub_bg trace is undefined but in bg I see images/home/1.jpg and images/home/2.jpg
                                      where is the issues?
                                      thanks in advance.
                                      MELAS
                                      • 16. Re: image and text change when sublink clicked
                                        melas076 Level 1
                                        Dear Kglad,
                                        I didn't get any idea for this. please help me....
                                        Regards,
                                        MELAS
                                        • 17. Re: image and text change when sublink clicked
                                          melas076 Level 1
                                          MR Kglad,
                                          I solved it but thanks you very much for your time spent with me.
                                          you missed something in the code but i don't know you know this or not
                                          regards,
                                          MELAS
                                          • 18. Re: image and text change when sublink clicked
                                            you're welcome.
                                            • 19. Re: image and text change when sublink clicked
                                              melas076 Level 1
                                              dear Kglad,
                                              i want to know how to reset the autosize of TextField, because i set _root.mc.TextField.autosize = true; then when i clicked on sublink the size didn't change....
                                              how?
                                              regards,
                                              MELAS
                                              • 20. Re: image and text change when sublink clicked
                                                try:
                                                _root.mc.textfield.autoSize="left";  // don't use TextField for an instance name.
                                                • 21. Re: image and text change when sublink clicked
                                                  melas076 Level 1
                                                  i did but i don't see any change......
                                                  because my scrollbar is the same, it takes the first time the size of textfield on load..... then when i click on submenu it doesn't reset the scrollbar for textfield....
                                                  any idea?
                                                  regards,
                                                  MELAS
                                                  • 22. Re: image and text change when sublink clicked
                                                    that's because you almost certainly don't know the path to your textfield.  to confirm, use:
                                                    trace(_root.mc.textfield);  // use the correct textfield instance name.
                                                    • 23. Re: image and text change when sublink clicked
                                                      melas076 Level 1
                                                      it is correct path, but i think you didn't understand me.....
                                                      the first, Textfield loaded Text and scrollbar works.
                                                      then, when i click on one of the sublink, it changes text in the correct _root.mc.TextField, it changes Text but scrollbar not work.
                                                      the scrollbar is taking the size of the first time Textfield loaded but it is scrollable with not correct Textfield size....
                                                      I hope you understood me ..
                                                      Thanks in advance..
                                                      regards,
                                                      MELAS
                                                      • 24. Re: image and text change when sublink clicked
                                                        what's
                                                        trace(_root.mc.TextField)
                                                        show?
                                                        • 25. Re: image and text change when sublink clicked
                                                          melas076 Level 1
                                                          When i trace, it gives me this : _level0.bg_home.content_mc2.txt
                                                          • 26. Re: image and text change when sublink clicked
                                                            i don't understand what you're trying to do.
                                                            • 27. Re: image and text change when sublink clicked
                                                              melas076 Level 1
                                                              i am trying to do about the scrollbar.
                                                              then, when i click on one of the sublink, it changes text in the correct _root.mc.TextField, it changes Text but scrollbar not work because it doesn't change the content._height
                                                              the scrollbar is taking the same size of the first time Textfield loaded but it is scrollable with not correct content._height size.
                                                              regards,
                                                              MELAS
                                                              • 28. Re: image and text change when sublink clicked
        the scrollbar doesn't work, at all?  or, it works but doesn't scroll the correct amount of text?
        • 29. Re: image and text change when sublink clicked
        melas076 Level 1
        yes it works but when i clicked on sublink which has a small text, so the scrollbar will disappear normally.....
        anyway i solved today....
        thanks a lot for your help!
        do you have any idea for the scrollbar which i posted last 2 days in a new post?
        regards,
        MELAS
