1 Reply Latest reply on Sep 19, 2011 1:04 PM by SergeAzel
    MUST be a better way...  !
    Tony Heagren Level 1
      Hi all,
      I've recently inherited a project which needs to load random images from a dir on the server.
      the previous developer has this code on every swf (there are over 40):
      pic_arr = ["images/randoms/1", "images/randoms/2","images/randoms/3", "images/randoms/4", "images/randoms/5", "images/randoms/6", "images/randoms/7",
                 "images/randoms/8", "images/randoms/9","images/randoms/10","images/randoms/11", "images/randoms/12","images/randoms/13","images/randoms/14",
                 "images/randoms/15","images/randoms/16","images/randoms/17","images/randoms/18","images/r andoms/19","images/randoms/20","images/randoms/21",
                 "images/randoms/22","images/randoms/23","images/randoms/24","images/randoms/25","images/r andoms/26","images/randoms/27","images/randoms/28",
                 "images/randoms/29", "images/randoms/30","images/randoms/31","images/randoms/32"];
          ranNum = Math.floor(Math.random()*pic_arr.length);
      I need to update this as the number of random images is set to increase to about 1000 and I don't fancy hand coding the above to include "images/randoms/999" ,  "images/randoms/1000"  !!!
      Can anyone suggest a solution where I can keep a single .as file on the server which handles this and then a line of code in each swf which imports it ?
      All and any ideas of finding a better solution MUCH appreciated.
      FYI - the site is built in php with a Flash fornt end so easy to use php to count the contents of the "images/randoms" dir and pass that number as a flashVar if that helps.
      Best wishes
        • 1. Re: MUST be a better way...  !
          Well, I don't know about importing an .as file or anything,
          but experience in other languages can let me help solve your array numbering problem:
          This isn't tested code, but should be close to right.
          var array_size = 1000;     //or however large it is
          var pic_arr; //just in case
          pic_arr = new Array();
          for(var i = 1; i <= array_size; i++)
               pic_arr[i] = "images/randoms/" + String(i);  //String(integer) should convert the integer to a string
          // From here we would use the rest of your original code
          OR we could do even better:
          This saves the time and space of creating such a large array!
          var array_length = 1000;
          ranNum = Math.floor(Math.random()*array_length) + 1;
          I don't know about the rest of your problems thouhg =( sorry
