1. Re: New sequence - Drag to icon versus New Sequence dialog box
joe bloe premiere Sep 18, 2011 4:38 PM (in response to Sengstack)It is a shortcut with some imperfections best explained by Colin's post here:
edit:
In my opinion, you are using the shortcut correctly...
you should always check that it has created exactly what you intended.
2. Re: New sequence - Drag to icon versus New Sequence dialog box
Sengstack Sep 18, 2011 4:51 PM (in response to joe bloe premiere)Colin's post does not answer some of the issues raised in the post:
1) Why get a red line in the sequence when using the correct sequence preset?
2) Why get a yellow line when using a shortcut that does not work as it should (in particular since the shortcut-created sequence presumes the footage is interlaced when it is progressive)?
Doing some more checking on the forum, it appears that CS5 (and its predecessors) have had problems with AVCHD. To at least fix the issue raised in question #1, select the MTS files in the Project panel, choose Modify > Interpret Footage, and then change Field Order to Conform to: No Fields (Progressive Scan).
Then at least, the red lines in the sequences change to yellow.
But that begs the question: why does P Pro mis-interpret AVCHD footage?
Jeff
3. Re: New sequence - Drag to icon versus New Sequence dialog box
joe bloe premiere Sep 18, 2011 4:57 PM (in response to Sengstack)1) Why get a red line in the sequence when using the correct sequence preset?
Dunno.
"...Panasonic AG-HMC150 and shooting at 1080 30p..."
Are you certain that it is progressive?
Have you checked the footage with MediaInfo or other utility?
I am not familiar with the camera.
4. Re: New sequence - Drag to icon versus New Sequence dialog box
Sengstack Sep 18, 2011 5:10 PM (in response to joe bloe premiere)It's progressive.
5. Re: New sequence - Drag to icon versus New Sequence dialog box
joe bloe premiere Sep 18, 2011 5:19 PM (in response to Sengstack)Maybe...
When shooting 1080p30.the vast majority of cameras
will out this as 30P contained within a 60i stream.
This is because in the original specifications for HD-SDi
there was no allowance for 1080p, only for 1080i.
This signal is called PsF (Progressive Segmented Frame).
6. Re: New sequence - Drag to icon versus New Sequence dialog box
Sengstack Sep 18, 2011 5:30 PM (in response to joe bloe premiere)It's 1080 30p. The Interpret Footage command confirms that.
7. Re: New sequence - Drag to icon versus New Sequence dialog box
Colin Brougham Sep 18, 2011 5:36 PM (in response to Sengstack)But that begs the question: why does P Pro mis-interpret AVCHD footage?
It's a bug--plain and simple. There's no other reason than that. This exists in CS5 and CS5.5 (assuming you're referring to AVCHD 1080p30). I haven't seen this with 720p60--for me, its interpreted as progesive--so I'll take your word on that.
Report it here: Adobe Feature Request/Bug Report Form
In the meantime, just interpret the footage as progressive after import, and continue as you otherwise would.
8. Re: New sequence - Drag to icon versus New Sequence dialog box
Sengstack Sep 18, 2011 5:50 PM (in response to Colin Brougham)Colin,
I submitted two bug reports for the drag and drop method resulting in the wrong sequence settings and using a sequence with the correct settings but getting the red line displayed at the top of the sequence.
Jeff
9. Re: New sequence - Drag to icon versus New Sequence dialog box
Colin Brougham Sep 18, 2011 5:53 PM (in response to Sengstack)Well, actually, the resulting behavior in the sequence is absolutely correct--and the drag and drop method is working correctly. The actual bug is in the interpretation of the footage itself--instead of being properly interpreted as progressive, it's interpreted as interlaced. As a result, a sequence created using the drag and drop method matches the footage--it's interlaced, and you get a yellow bar. When you manually create an AVCHD 30p sequence and drop these clips into it, you have a mismatch--progressive sequence, interlaced footage--and that's why you get the red bar.
Make sense?
10. Re: New sequence - Drag to icon versus New Sequence dialog box
Ann Bens Sep 19, 2011 8:36 AM (in response to Colin Brougham)I think Joe is right, reading the manual it says: for outputting and recording the 30 frame per second signal is converted to 60 fields per second interlaced.
11. Re: New sequence - Drag to icon versus New Sequence dialog box
Colin Brougham Sep 19, 2011 9:04 AM (in response to Ann Bens)The manual for what? The camera? It doesn't matter what the manual says; the point is that Premiere Pro is interpreting this particular flavor of footage incorrectly--or perhaps, isn't capable of interpreting it correctly. Whichever it is, footage shot in a progressive mode--regardless of how it is recorded into a file--should be interpreted correctly as progressive on import. Since the HMC150 has a 1080p30 recording mode, footage shot in this mode should be 1080p30 in Premiere Pro--it is not.
12. Re: New sequence - Drag to icon versus New Sequence dialog box
JSS1138 Sep 19, 2011 9:50 AM (in response to Colin Brougham)footage shot in a progressive mode--regardless of how it is recorded into a file--should be interpreted correctly as progressive on import.
How? If it actually is an interlaced signal, then it seems to me PP is behaving correctly to consider it such.
The real solution here is to get camera makers to stop recording progressive captures over interlaced signals. With solid state, we're no longer locked into specific recording rates. If it's captured progressive, record it that way.
13. Re: New sequence - Drag to icon versus New Sequence dialog box
Colin Brougham Sep 19, 2011 10:14 AM (in response to JSS1138)When a stream is flagged as progressive, even if it is recorded interlaced due to the way the particular codec works, Premiere Pro should be correctly reading that flag and interpreting the footage as progressive. I work with DVCPRO HD 1080p30 all the time, which, as recorded to a file, is actually 1080i60. Premiere Pro correctly interprets this as 1080p30, since the stream is flagged as such. The same applies to DVCPRO HD 1080p24--there is no such animal from a file standpoint; nevertheless, Premiere Pro can strip out the pulldown frames and render a true 24p stream. It should be noted that as of CS5.5, Premiere Pro still interprets DV 24p as Lower Field First instead of Progressive.
14. Re: New sequence - Drag to icon versus New Sequence dialog box
Sengstack Sep 19, 2011 3:36 PM (in response to Colin Brougham)Thanks for the extra info Colin.
