3 Replies Latest reply on Sep 29, 2011 7:15 AM by johndaigle
    Unable to see the map ids although they exist in the map.h file
    patpreeth
      I am creating a context sensitive help file using Robohelp 9.
      I have a map file (map.h) with all the map ids. However, when I import the map file into RoboHelp, and open the file for editing, some of the map ids are not visible in the "Edit Map ID" dialog. For example, map id: "1120" is not visible in the "Edit Map IDs" dialog, although it is present in the map.h file.
      Due to this reason, I am unable to assign a topic to the map id. When I try to create a map id with the same number, a message is displayed as "Map ID already exists".
      Is there a way to make all the map ids visible? How do I get to see all the map ids.
      Thanks.
