1 Reply Latest reply on Sep 19, 2011 9:48 AM by Flex harUI
    Datagrid columns widths
    archemedia Level 4
      Hi all,
      I have an urgent question concerning dataGrid column widhts.
      Here is a simplified code:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
          layout="vertical" minWidth="955" minHeight="600" >
          <mx:Script>
              <![CDATA[
                  import mx.collections.ArrayCollection;
                  [Bindable] private var dp:ArrayCollection = new ArrayCollection(
                      {id: 1, label: "Item one"},
                      {id: 2, label: "Item two"}
                  public function init():void
          </mx:Script>
          <mx:DataGrid id="dg" height="100%" dataProvider="{dp}">
              <mx:columns>
                  <mx:DataGridColumn headerText="C1" width="200" dataField="label"/>
                  <mx:DataGridColumn headerText="C2">
                      <mx:itemRenderer>
                          <mx:Component>
                              <mx:HBox width="100%" horizontalScrollPolicy="off">
                                  <mx:Script>
                                      <![CDATA[
                                          import mx.controls.CheckBox;
                                          override public function set data(value:Object):void
                                              super.data = value;
                                              for (var i:int = 0; i < 5; i++)
                                                  var cb:CheckBox = new CheckBox();
                                                  cb.label = "cb" + i;
                                                  contentHolder.addChild(cb);
                                  </mx:Script>
                                  <mx:HBox id="contentHolder" width="100%" horizontalScrollPolicy="off"/>
                              </mx:HBox>
                          </mx:Component>
                      </mx:itemRenderer>
                  </mx:DataGridColumn>
              </mx:columns>
          </mx:DataGrid>
      </mx:Application>
      As you can see, within the set data functions, content is added to the itemRenderer. This is done AFTER the datagrid is initialized.
      Therefore, the column is not wide enough.
      I have two problems now:
      1. How can I calculate the widht of the contentHolder HBox?
      2. How can I redraw the datagrid's columns based on this calculated width?
      Any help much appreciated.
      Dany
