2 Replies Latest reply on Sep 19, 2011 6:57 AM by kglad
    height problem
    melas076
      Dear All,
      in content_mc, i did TextField._height = output.lenght /2 which is 615; and i want to set the same height for the content_mc so i did _root.content_mc._height = _root.content_mc.TextField._height; it gives me the size 15.15; why?
      any help?
      regards,
      MELAS
        • 1. Re: height problem
          The first thing you should do is not use "TextField" as a name for anything.  It is an AS2 class name, so that might be causing you a problem.
          What is TextField supposed to be?  Why can't you just assign a variable to the content_mc and use that...
          content_mc.heightVar = output.lenght/2;
          and later use
          content_mc_height = content_mc.heightVar;
          • 2. Re: height problem
            because you asigned content_mc's _height before the textfield's height changed.   the textfield's height wasn't changed, when you tried to assign content_mc's _height, either because you didn't set it correctly or you're using a component where there's a delay in the textfield size change.
