5 Replies Latest reply on Jan 19, 2012 6:28 PM by John Mensinger
    placing layered PS5 graphics
    powerdogvt Level 1
      Bit of a problem with PS layers. I place the file into a new ID page, see that all my layers are visible in options window, and click the mouse. I get a single layer (Layer 1) in ID, with no separate pieces. This is the same whether I use the ID or PS layer visibility. Am I missing something? Thanks.
        • 1. Re: placing layered PS5 graphics
          BobLevine MVP & Adobe Community Professional
          Yes, you are. Photoshop layers do not become InDesign layers.
          You can turn them on or off but it still remains a single graphic.
          Bob
          • 2. Re: placing layered PS5 graphics
            LM64
            I am a greetings card designer and have a similar problem, I need both my layers to be visible that I have placed from photoshop into indesign.
            What can I do as I need to work on the layers in photoshop first but then send to printer showing the two layers, one for the background and one for emboss drawing. Any help appreciated.
            • 3. Re: placing layered PS5 graphics
              Bo LeBeau Level 4
              You can place a layered Photoshop file in InDesign and select which layers to show during the place procedure, check the import options in the lower left of the dialog window, or just hold down the Shift key as you place.
              But, you can also change the visible layers in an already place image, in Indesign go the Object Menu - Object Layer Options.
              You can turn on or off the layers at any time, just make sure the image is selected first.
              • 4. Re: placing layered PS5 graphics
                AsheDesign.com
                So are you saying there is no way to edit the individual photoshop layers in indesign once it's placed?
                • 5. Re: placing layered PS5 graphics
                  John Mensinger Adobe Community Professional & MVP
                  Depends on what you mean by "edit." If you want to affect pixels, you'll have to edit in Photoshop. Fortunately, that's not so hard using InDesign's Edit Original feature.
                  If your objective is to separate Photoshop layers to InDesign layers, (presumably so that you can move them or control their visibility independently of each other), that's not so hard either. Just place the Photoshop image and copy it. Make a new InDesign Layer, paste-in-place, repeat for each layer, then use Object Layer Options to hide/reveal Photoshop layers of each copy as desired.
