1 Reply Latest reply on Sep 19, 2011 11:06 AM by MurraySummers
    Online Quiz
    NeilSBob
      Hello,
      Ive made an online quiz. There is a timer to time out the questiona and go to the next question after 30secs, but it does not go to the next question automatically. The code is here:
      <%@ Import Namespace="System.Xml" %>
      <script language="VB" runat="server">
      'Relative file path to XML data
      Dim strXmlFilePath as String = Server.MapPath("quiz.xml")
      Dim xDoc as XmlDocument = New XmlDocument()
      Dim intTotalQuestion as Integer
      Dim intQuestionNo as Integer = 1
      Dim intScore as Integer = 0
      Dim arrAnswerHistory as new ArrayList()
      Sub Page_Load(src as Object, e as EventArgs)
                'Load xml data
                xDoc.Load(strXmlFilePath)
                'Start a new quiz?
                If Not Page.IsPostBack Then
                          'Yes! Count total question
                          intTotalQuestion = xDoc.SelectNodes("/quiz/mchoice").Count
                          'Record start time
                          ViewState("StartTime") = DateTime.Now
                          ShowQuestion(intQuestionNo)
                End If
      End Sub
      Sub btnSubmit_Click(src as Object, e as EventArgs)
                'Retrieve essential variables from state bag
                intTotalQuestion = ViewState("TotalQuestion")
                intQuestionNo = ViewState("QuestionNo")
                intScore = ViewState("Score")
                arrAnswerHistory = ViewState("AnswerHistory")
                'Correct answer?
                If rblAnswer.SelectedItem.Value = ViewState("CorrectAnswer") Then
                          intScore += 1
                          arrAnswerHistory.Add(0)
                Else
                          arrAnswerHistory.Add(rblAnswer.SelectedItem.Value)
                End If
                'End of quiz?
                If intQuestionNo=intTotalQuestion Then
                          'Yes! Show the result...
                          QuizScreen.Visible = False
                          ResultScreen.Visible = True
                          'Render result screen
                          ShowResult()
                Else
                          'Not yet! Show another question...
                          QuizScreen.Visible = True
                          ResultScreen.Visible = False
                          intQuestionNo += 1
                          'Render next question
                End If
      End Sub
      Sub ShowQuestion(intQuestionNo as Integer)
                Dim xNodeList as XmlNodeList
                Dim xNodeAttr as Object
                Dim strXPath as String
                Dim i as Integer
                Dim tsTimeSpent as TimeSpan
                strXPath = "/quiz/mchoice[" & intQuestionNo.ToString() & "]"
                'Extract question
                lblQuestion.Text = intQuestionNo.ToString() & ". " & xDoc.SelectSingleNode(strXPath & "/question").InnerXml
                'Extract answers
                xNodeList = xDoc.SelectNodes(strXPath & "/answer")
                'Clear previous listitems
                rblAnswer.Items.Clear
                For i = 0 to xNodeList.Count-1
                          'Add item to radiobuttonlist
                          rblAnswer.Items.Add(new ListItem(xNodeList.Item(i).InnerText, i+1))
                          'Extract correct answer
                          xNodeAttr = xNodeList.Item(i).Attributes.ItemOf("correct")
                          If not xNodeAttr is Nothing Then
                                    If xNodeAttr.Value = "yes" Then
                                              ViewState("CorrectAnswer") = i+1
                                    End If
                          End If
                Next
                'Output Total Question
                lblTotalQuestion.Text = intTotalQuestion
                'Output Time Spent
                tsTimeSpent = DateTime.Now.Subtract(ViewState("StartTime"))
                lblTimeSpent.Text = tsTimeSpent.Minutes.ToString() & ":" & tsTimeSpent.Seconds.ToString()
                'Store essential data to viewstate
                ViewState("TotalQuestion") = intTotalQuestion
                ViewState("Score") = intScore
                ViewState("QuestionNo") = intQuestionNo
                ViewState("AnswerHistory") = arrAnswerHistory
      End Sub
      Sub ShowResult()
                Dim strResult as String
                Dim intCompetency as Integer
                Dim i as Integer
                strResult  = "<center>"
                strResult += "<h3>Quiz Result</h3>"
                strResult += "<p>Points: " & intScore.ToString() & " of " & intTotalQuestion.ToString()
                strResult += "<p>Your Competency: " & Int(intScore/intTotalQuestion*100).ToString() & "%"
                strResult += "</center>"
                strResult += "<h3>Quiz Breakdown:</h3>"
                For i = 1 to intTotalQuestion
                          strXPath = "/quiz/mchoice[" & i.ToString() & "]"
                          strResult += "<b>" & i.ToString() & ". " & xDoc.SelectNodes(strXPath & "/question").Item(0).InnerXml & "</b><br>"
                          If arrAnswerHistory.Item(i-1)=0 Then
                                    strResult += "<font color=""green""><b>Correct</b></font><br><br>"
                          Else
                                    strResult += "<b>You answered:</b> " & xDoc.SelectNodes(strXPath & "/answer[" & arrAnswerHistory.Item(i-1).ToString() & "]").Item(0).InnerXml & "<br>"
                                    strResult += "<font color=""red""><b>Incorrect</b></font><br><br>"
                          End If
                Next
                lblResult.Text = strResult
      End Sub
      </script>
      <script src="https://ajax.googleapis.com/ajax/libs/jquery/1.4.2/jquery.min.js"></script>
      $(document).ready(function(){
                $(".chp1").click(function(){
                $(".quizlist1").slideToggle("slow");
                $(".chp2").click(function(){
                $(".quizlist2").slideToggle("slow");
          $(".chp3").click(function(){
                $(".quizlist3").slideToggle("slow");
          $(".chp4").click(function(){
                $(".quizlist4").slideToggle("slow");
          $(".chp5").click(function(){
                $(".quizlist5").slideToggle("slow");
          $(".chp6").click(function(){
                $(".quizlist6").slideToggle("slow");
          $(".chp7").click(function(){
                $(".quizlist7").slideToggle("slow");
          $(".chp8").click(function(){
                $(".quizlist8").slideToggle("slow");
      </script>
      var sec = 30;   // set the seconds
      var min = 00;   // set the minutes
      function countDown() {
        sec--;
        if (sec == -01) {
          sec = 59;
          min = min - 1;
        } else {
         min = min;
      if (sec<=9) { sec = "0" + sec; }
        time = (min<=9 ? "0" + min : min) + " min and " + sec + " sec ";
      if (document.getElementById) { theTime.innerHTML = time; }
        SD=window.setTimeout("countDown();", 1000);
      if (min == '00' && sec == '00') { sec = "00"; window.clearTimeout(SD); }
      function addLoadEvent(func) {
        var oldonload = window.onload;
        if (typeof window.onload != 'function') {
          window.onload = func;
        } else {
          window.onload = function() {
            if (oldonload) {
              oldonload();
            func();
      addLoadEvent(function() {
        countDown();
      </script>
      <html>
      <head>
      <title>Dhruv Asher | Chemistry Quiz</title>
      <link rel="stylesheet" href="style.css" type="text/css" media="screen" />
      <link rel="stylesheet" type="text/css" href="quiz.css">
      </head>
      <body>
      <div align="center" style="background-color:#333">
        <div class="wrapper">
          <div class="innerwrapper">
            <div class="header">
            <a href="http://crazypencilmedia.com/da.html"><img src="images/DA.png" style="width:264px; height:75px; float:left"></a>
            <a id="home" href="/da.html" title="Home"><span></span></a>
            <a id="about" href="#" title="About Me"><span></span></a>
            <a id="Courses" href="/courses.html" title="Courses Offered"><span></span></a>
            <a id="Forum" href="#" title="Forums"><span></span></a>
            <a id="Gallery" href="/images.html" title="Image/Video Gallery"><span></span></a>
            <a id="Students" href="#" title="Students Page"><span></span></a>
            <a id="contact" href="#" title="contact Page"><span></span></a>
            </div>
            <div class="container">
              <div class="quiz"> <span id="QuizScreen" runat="server" style="text-align:center">
                <form runat="server">
                  <div class="headingq">CHEMISTRY QUIZ</div>
                  <br/>
                  <div class="containerq">
                  <div class="instructions">Instructions: <br />
                    1. There are 30 questions for 30 marks.<br />
                    2. You have 30 seconds for each question.<br />
                    3. After you have answered the question, please click on the next button to continue. <br />
                    4. Print out a copy of the marksheet for submission. <br />
                    <br />
                    Time Left: <span id="theTime" class="timeClass"></span><br /><br/>
                  <asp:label id="lblQuestion" runat="server" />
                  </b><br>
                  <div style="padding-left:40px;">
                    <asp:radiobuttonlist
                     id="rblAnswer"
                           RepeatDirection="vertical"
                           TextAlign="right"
                           RepeatLayout="table"
                           runat="server" />
                    <br>
                    <asp:requiredfieldvalidator
                           ControlToValidate="rblAnswer"
                           ErrorMessage="Please pick an answer!"
                           runat="server" />
                    <br>
                  </div>
                  <div class="submit">
                    <asp:button id="btnSubmit" class="button" text="  Next  " onClick="btnSubmit_Click" runat="server" />
                  </div>
                  <div class="footerq">Total No. of questions:
                    <asp:label id="lblTotalQuestion" runat="server" />
                           Time spent:
                    <asp:label id="lblTimeSpent" runat="server" />
                  </div>
                </form>
                </span> <span id="ResultScreen" runat="server">
                <asp:label id="lblResult" runat="server" />
                </span> </div>
            </div>
        </div>
      </div>
      <div class="footer">
        <div style="float:left; font-size:15px; color:#FFF; margin-top:10px; margin-left:5px;"><img src="images/copy.png" width="10px" height="10px;"> 2011. Dhruv Asher. All Rights Reserved.</div>
        <div style="float:right; font-size:15px; color:#FFF; margin-top:10px; margin-right:5px;">Site Maintained by <a href="http://www.crazypencilmedia.com">Crazy Pencil Media</a></div>
      </div>
      </div>
      </div>
      </div>
      </body>
      </html>
      Please Help
