1. Re: Photoshop CS5 closes when selecting “File-Automate-Batch”
MTSTUNER Sep 19, 2011 10:19 PM (in response to bkoopers)From reading the different posts about this problem, the answer seems to be removing the Twain plugin resolves the issue
or possibly updating your scanner drivers. Have you installed the optional Twain plugin into photoshop cs5?
http://forums.adobe.com/message/3768879
MTSTUNER
2. Re: Photoshop CS5 closes when selecting “File-Automate-Batch”
bkoopers Sep 20, 2011 7:37 PM (in response to MTSTUNER)Thanks.That was it. I am using an Epson Perfection V500 Photo Flatbed Scanner. If I rename the Photoshop Twain driver plug-in file by putting a "~" (tilde) in front of the filename, then the Batch function works. I will have to remove the "~" when I want to scan directly into Photoshop.
According to the posts at the link you provided, Adobe says this is an Epson problem and Epson says this is an Adobe problem. Unfortunately, that means that this problem is unlikely to be fixed in the near future (if ever).
