3 Replies Latest reply on Sep 21, 2011 12:09 AM by pramod.rao
    how to validate and saving the values of one combo box and two text boxes in flex4 mxml app with as3
    Venkatesan Balasubramanian Level 1
      helllo all,
                  i am working on flex4 web application with as3.
      i have one doubt, i created a mxml it have two text boxes,one save button and one combo box .its has two option like Percentage and amount.
      my needs are i given here,
              need 1:   when i select amount option that two text boxes should be not editable.when i select percentage option tat two text box will be editable.
             need  2:    when i select percentage option in combox and that two text boxes are empty then click save button --->i want to display warning msg
            need 3:  when i select amount option in combox and that two boxes are emptu click save button--->i dont want any warning message.
      how i validate this and how i write save function for this.
      any suggession or snippet codes are welcome.
      Thanks in advance,
      B.venkatesan
        • 1. Re: how to validate and saving the values of one combo box and two text boxes in flex4 mxml app with as3
          pramod.rao Level 1
          This is simply putting your logic into code. Why do you need code snippets for this?
          • 2. Re: how to validate and saving the values of one combo box and two text boxes in flex4 mxml app with as3
            hi pramod,
            i already tried this but ,in that one condition is working bt another one not working i am giving my code here,
            this is my sample code:
            combo box id=baseAmtPer
            textbox1 id= maxCommAmt.text
            text box id=baseAmtPer.text
            if(((baseAmtPer.editable!=true)&&(maxCommAmt.editable!=true))&&((baseA  mtPer.text=="")&&(maxCommAmt.text==""))||(baseAmtPer.text=="")||(maxCo mmAmt.text==""))-->this condition not allowing while i am selecing Amount in combo box BOTH TEXT BOX WILL BE EMPTY .how to solve this issue
                                    Alert.show("Enter All fields", "Information");
                                else
                                  //  some codings
            send ur useful suggession
            Thanks ,
            B.venkatesan.
            • 3. Re: how to validate and saving the values of one combo box and two text boxes in flex4 mxml app with as3
              pramod.rao Level 1
              Looks like you are trying to do too much at one time. Try hooking the events properly
              The comboBox close event can do something like this
              protected function toggleTextEditing(event:DropDownEvent):void
                             if(this.optionCmb.selectedItem.label == "Percentage")
                                       this.text1.editable = true;
                                       this.text2.editable = true;
                             else if(this.optionCmb.selectedItem.label == "Amount")
                                       this.text1.editable = false;
                                       this.text2.editable = false;
              The button click event can do something like
              protected function save(event:MouseEvent):void
                                            if(this.text1.text == "" && this.text2.text == "")
                                                           Alert.show("Text is empty");
                                                           return;
                                   else
              If you can put in your entire code, may be I can have a look at it to see if I can find anything wrong there.
              -Pramod
              http://www.flexmycode.com
