3 Replies Latest reply on Sep 21, 2011 9:16 PM by John Hawkinson
    Linked Excel table. Convert commas to points
    Steve Fairbairn Level 5
      See this thread:
      http://forums.adobe.com/thread/903846?tstart=0
      I have set up a GREP search according to Haakenlid's instructions in post 11. It works fine:
      _____
      Find three digits preceeded with a comma:
      ,(\d{3})
      Replace with a dot (or better IMO a fixed with non breaking space, "~s" in InDesign's GREP notation)
      .$1
      _____
      Now I am wondering if it can be made into a script that can be added on this script (below) that removes cell insets so that the whole operation can be done with a single script.
      I have no experience with scripting, so if anyone can help, it would be greatly appreciated.
      _____
      //DESCRIPTION: Updates any linked tables and resets top and bottom insets of cells
        In testing this, I realized that there are many ways that a linked Excel sheet
        will auto update (in fact, I was unable to persuade ID not to update the link so
        I haven't actually tested the branch where the link is updated, but I have used
        that syntax before on linked graphics, so it ought to work).
        So, the script fixes the insets on every linked Excel sheet whether or not its
        link needs updating. It does not even see unlinked tables.
      myDoc = app.activeDocument;
      myLinks = myDoc.links;
      myLim = myLinks.length;
      for (i = myLim - 1; i >= 0; i--) {
      if (myLinks[i].linkType == "Microsoft Office Excel 2007 Import Filter") {
        if (myLinks[i].needed) {
         myLinks[i].update();
        // Whether or not we updated, fix insets because there might have been an auto update
        myTable = myLinks[i].parent.tables[0];
        myTable.cells.everyItem().bottomInset = 0;
        myTable.cells.everyItem().topInset = 0;
        • 1. Re: Linked Excel table. Convert commas to points
          Haakenlid Level 3
          This should do it
            // changes thousand separators from commas to periods in every cell in the table
            app.findGrepPreferences = null;
            app.changeGrepPreferences = null;
            app.findGrepPreferences.findWhat = ",(\\d{3})";
            app.changeGrepPreferences.changeTo = ".$1";
            myTable.changeGrep();
          • 2. Re: Linked Excel table. Convert commas to points
            Brilliant. Thanks.
            Now I am like a dog with two tails :-)
            • 3. Re: Linked Excel table. Convert commas to points
              John Hawkinson Level 5
              As might have been clear from Steve's prior post on a similar topic, this is a bad idea:
              Because there are other link types you probably want to match, at a minimum, "Microsoft Excel Import Filter" as well.
              I'm not really sure what the mimal set is for such things, but I suppose I would probably go with
              if (myLinks[i].linkType.match(/Excel/) {
