6 Replies Latest reply on Sep 20, 2011 3:47 PM by Ned Murphy
    scrollbar problem
    melas076 Level 1
      Dear,
      i have 2 scrollbars in each MC. when i scroll with mouse it scrolls all scrollbars and not the one i select..
      anyone has idea???
      regards,
      MELAS
        • 1. Re: scrollbar problem
          Do you have any code to show that relates to using the mouse to control the scrollbars?
          • 2. Re: scrollbar problem
            melas076 Level 1
            Dear Ned,
            This is the code of Mc2  and the same for Mc1 but removes 2 in"content_mc2", "mask_mc2" and "scroll_mc2"
            stop();
            import com.greensock.*;
            var newsXML:XML = new XML();
            newsXML.ignoreWhite = true;
            newsXML.load("xml/Profile.xml");
            var output:String = "";
            newsXML.onLoad = function(success) {
                if (success) {
                    var ref = _root.prohome;
                    ref.content_mc2.ProfileHome.autoSize = true;
                     ref.content_mc2.ProfileHome.multiline = true;
                    ref.content_mc2.ProfileHome.wordWrap = true;
                    var news:Array = newsXML.childNodes[0].childNodes[0].firstChild;
                    //var hlink = news[i].attributes.links;
                    //trace(news);
                    ref.content_mc2.ProfileHome.htmlText = news;
                    ref.content_mc2.setMask(ref.mask_mc2);
            //trace(newsheight);
            //this.content_mc._height =  _root.content_mc.newsTXT._height;
            //trace( );
            if(ref.mask_mc2._height<ref.content_mc2._height)
                var scroll_c2 = ref.attachMovie("ScrollBar","scroll_mc2",1,{_x:ref.mask_mc2._x+ref.mask_mc2._width-10,_y: ref.mask_mc2._y});
                    scroll_c2.setHeight(ref.mask_mc2._height);
                    scroll_c2.PageSize  = ref.mask_mc2._height;
                    scroll_c2.McHeight  = ref.content_mc2._height+40;
                    scroll_c2.Chunks = ref.content_mc2._height+40-ref.mask_mc2._height;
                    scroll_c2._parent.onScroll = function()
                        TweenLite.to(ref.content_mc2, 1, {_y:ref.mask_mc2._y - this.scroll_mc2.getScrollPos()});
                        //ref.content_mc._y = ref.mask_mc._y - this.scroll_mc.getScrollPos();
                    scroll_c2.init();
                    scroll_c2.onPress = function(){}
            var mouseListener2 = new Object();
            mouseListener2.onMouseWheel = function( wheelMotion2 ){
            scroll_c2.scr_pos -= wheelMotion2 *2;
            scroll_c2.Update();
            Mouse.addListener( mouseListener2 );
                }else{
                    ref.content_mc2.ProfileHome.htmlText = "Data file did not load.";
            thanks in advance...
            MELAS
            • 3. Re: scrollbar problem
              melas076 Level 1
              Dear Ned,
              Any idea for this issue??
              Regards,
              Melas
              • 4. Re: scrollbar problem
                melas076 Level 1
                i forget to post this code of scrollbar in ScrollBar.as in folder "com/go4flash/ScrollBar.as".
                class com.go4flash.ScrollBar extends MovieClip
                    public var enabled;
                    public var scr_pos;
                    public var McHeight;
                    public var PageSize;
                    public var FullBarMc;
                    public var McScaledStep;
                    public var step;
                    public var ArrowDown;
                    public var height;
                    public var Chunks;
                    public function ScrollBar()
                        this.enabled    = true;
                        this.scr_pos    = 0;
                        this.createInterface();
                        this.init();
                    public function init()
                            if(this.McHeight > this.PageSize)
                            else
                                this.FullBarMc.Slider._visible = false;
                                this.enabled = false;
                            if(this.enabled)
                                var trg_coef        = this.PageSize/this.McHeight;
                                this.McScaledStep    = (this.McHeight-this.PageSize)/(this.Chunks-1);
                                var sh                = this.FullBarMc.Bar._height*trg_coef;
                                if(sh < 10)            this.FullBarMc.Slider.SliderMc._height = 10;
                                else                 this.FullBarMc.Slider.SliderMc._height = sh;
                                var scr_coef    = this.FullBarMc.Slider._height/this.FullBarMc.Bar._height;
                                var trg_h        = (this.McHeight-this.PageSize);
                                var scr_h        = (this.FullBarMc.Bar._height-this.FullBarMc.Slider._height);
                                this.step        = scr_h/(this.Chunks-1);
                                if(!this.FullBarMc.Slider._visible)
                                    this.FullBarMc.Slider._visible = true;
                            this.Update();
                    public function onMoveSlider()
                      if(this.enabled)
                         this.scr_pos = this.setRanges(Math.round((this.FullBarMc.Bar._ymouse-this.FullBarMc.Slider.yOffset)/this .step),0,this.Chunks-1);
                         this.Update();
                    public function getScaledStep()
                        return this.McScaledStep;
                    public function Update()
                            this.scr_pos                = this.getScrollPos();
                            this.FullBarMc.Slider._y    = this.scr_pos*this.step;
                            this._parent.onScroll();
                    public function getScrollPos(){
                            return this.setRanges(this.scr_pos,0,this.Chunks-1);
                    public function setScrollPos(nPos){
                            this.scr_pos = this.setRanges(nPos,0,this.Chunks-1);
                            this.Update();
                    public function setRanges(x,l,r)
                            if(x <= l)    return l;
                            if(x >= r)    return r;
                                        return x;
                    public function setHeight(sz){
                        if(sz > 25)
                         this.FullBarMc.Bar.BarBgrMc._height    = sz-this.ArrowDown._height*2;
                         this.ArrowDown._y                        = sz;//-this.ArrowDown._height;
                         this.init();
                    public function setEnabled(boolVal)
                        this.enabled = boolVal;
                    public function createInterface()
                        var h = this._height;
                        this._xscale = 100;
                        this._yscale = 100;
                        if(this.height!=undefined)    this.setHeight(this.height);
                        else                        this.setHeight(h);
                to download this free scrollbar : http://blog.go4flash.com/downloads/sources/SimpleScrollBar.zip
                please help!!!!!
                • 5. Re: scrollbar problem
                  melas076 Level 1
                  Mr. Ned,
                  are you there?
                  did you see this issues?
                  any ideas for this?
                  regards,
                  MELAS
                  • 6. Re: scrollbar problem
                    The key to finding the problem likely lies in comparing the code you have for 1 and 2 to see how/where they end up sharing the same objects.
                    If you have any provision for making all of the files involved with this available for download, that might prove helpful, though I might not be able to open them.
