1 Reply Latest reply on Sep 20, 2011 11:06 PM by Vibhuti Gosavi(InfoCepts)
    how to write save function based on combo box selection datas in flex4 mxml app with as3
    Venkatesan Balasubramanian
      hi all,
        i am working on flex4 web application with as3.
      i have one doubt, i created a mxml it have two text boxes,one save button and one combo box .its has two option like Percentage and amount.
      my needs are i given here,
            need 1:   when i select amount option that two text boxes should be not editable.when i select percentage option tat two text box will be editable.
            need 2:   when i select percentage option in combox and that two text boxes are empty then click save button --->i want to display warning msg
            need 3:   when i select amount option in combox and that two boxes are emptu click save button--->i dont want any warning message.
      how i validate this and how i write save function for this.
      this is my sample code:
      combo box id=baseAmtPer
      textbox1 id= maxCommAmt.text
      text box id=baseAmtPer.text
      if(((baseAmtPer.editable!=true)&&(maxCommAmt.editable!=true))&&((baseAmtPer.text=="")&&(ma xCommAmt.text==""))||(baseAmtPer.text=="")||(maxCommAmt.text==""))-->this condition not allowing while i am selecing Amount in combo box BOTH TEXT BOX WILL BE EMPTY .how to solve this issue
                              Alert.show("Enter All fields", "Information");
                          else
                            //  some codings
        • 1. Re: how to write save function based on combo box selection datas in flex4 mxml app with as3
          Vibhuti Gosavi(InfoCepts) Level 3
          Please go through following Code:
                                           xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
                    <fx:Declarations>
                              <!-- Place non-visual elements (e.g., services, value objects) here -->
                    </fx:Declarations>
                    <fx:Script>
                              <![CDATA[
                                        import mx.collections.ArrayCollection;
                                        import mx.controls.Alert;
                                        import spark.events.IndexChangeEvent;
                                        protected function button1_clickHandler(event:MouseEvent):void
                                                   if(comboBox.selectedItem=="Percentage" && textBox1.text=="" && textBox2.text==""){
                                                             Alert.show("Enter values");
                                        protected function comboBox_changeHandler(event:IndexChangeEvent):void
                                                  if(comboBox.selectedItem=="Amount"){
                                                            textBox1.editable=false;
                                                            textBox2.editable=false;
                                                  else if(comboBox.selectedItem=="Percentage"){
                                                            textBox1.editable=true;
                                                            textBox2.editable=true;
                    </fx:Script>
                    <s:Button x="99" y="227" label="Save" click="button1_clickHandler(event)"/>
                    <s:TextInput x="99" y="104" id="textBox1"/>
                    <s:TextInput x="329" y="104" id="textBox2"/>
                    <s:ComboBox x="346" y="225" id="comboBox" change="comboBox_changeHandler(event)">
                              <s:dataProvider>
                                        <s:ArrayList>
                                                  <fx:String>Amount</fx:String>
                                                  <fx:String>Percentage</fx:String>
                                  </s:ArrayList>
                              </s:dataProvider>
                    </s:ComboBox>
          </s:Application>
          Thanks and Regards,
          Vibhuti Gosavi | vgosavi@infocepts.com | www.infocepts.com
