2 Replies Latest reply on Sep 21, 2011 10:01 AM by carojvi
    Ratio format 5:1
    carojvi Level 1
      Hello,
      Is it possible to have a formula that would result in something looking like 5:1 instead of 20%?
      I have 2 numeric fields, and I want the 3rd to show the ratio between the 2.
      Thank you,
      Caroline
        • 1. Re: Ratio format 5:1
          radzmar Adobe Community Professional & MVP
          this is only a formula from scratch, but it seems to work.
          Put it into the calculate event of the 3rd field (must be a text field!!!).
          Attention: This is ForcCalc not JavaScript, so make sure to select the correct language in the script editor.
          var a = NumberField1
          var b = NumberField2
          var max = Max(a, b)
          var min = Min(a, b)
          if (max gt 0 and min gt 0) then
                    var ratio
                    var perc = Round((100 / max) * min, 1)
                    var hundred = 100
                    for i = 1 upto Round(100/perc, 1) step 1 do
                                        hundred = hundred - perc
                                        ratio = i
                    endfor
                    $ = Concat(ratio, ":", 1)
          endif
          • 2. Re: Ratio format 5:1
            carojvi Level 1
            Thank you, it does seem to work! Genius
