0 Replies Latest reply on Sep 20, 2011 2:13 PM by Flexmaniac
    Embedding video player in TLF
    Flexmaniac
      Hi Guys,
      Can we add a video player to a Richeditable text, if yes what is wrong in the code below? I can see it adds to the editor but soesnt show up
      // Copyright (C) 2009 Rad3 Limited.
      // All Rights Reserved.
      // If you have received this file from a source other than Rad3,
      // then your use, modification, or distribution of it requires
      // the prior written permission of Rad3.
                                       xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" creationComplete="initApp();">
                <fx:Declarations>
                          <!-- Place non-visual elements (e.g., services, value objects) here -->
                </fx:Declarations>
                          <fx:Script>
                                    <![CDATA[
                                              import flashx.textLayout.edit.EditManager;
                                              import flashx.textLayout.edit.SelectionState;
                                              import mx.controls.Alert;
                                              import spark.components.VideoDisplay;
                                              import spark.components.VideoPlayer;
                                    private var _videoDisplay:VideoPlayer;
                                    private var _editManager:EditManager;
                                    private var _videoContainer:Sprite;
                                    private function initApp():void
                                              var videoPath:String = "sample_vid.flv";
                                              _videoDisplay = new VideoPlayer();
                                              _videoDisplay.source = videoPath;
                                              _videoContainer = new Sprite();
                                              _videoContainer.width = 200;
                                              _videoContainer.height = 200;
                                              //_videoDisplay.play();
                                              // add the video
                                              _videoContainer.addChild(_videoDisplay);
                                              _editManager = rte.textFlow.interactionManager as EditManager;
                                              _editManager.insertInlineGraphic(_videoContainer, 500,400, null, new SelectionState(rte.textFlow, 0, 0));
                          </fx:Script>
                          <s:RichEditableText id="rte" width="100%" height="100%"/>
      </s:Application>
