Chris,
My problem is somewhat similar. I have Firefox 6.0 & Flash Player 10.3.183.7. I use it to display charts. Problem is I can see the chart but not the legend (ex. Price) when I move across the chart. But this works fine with Internet Explorer. How do I fix this ?
Sunder
Hi Sunder,
I branched your post off into its own thread. The post you replied to was concerning installation and it sounds like you have a different issue.
Do you have a URL where I can see this behavior? If this is a private swf, can you create a new bug at bugbase.adobe.com and send me an email (ccampbel@adobe.com) with the swf attached so I can add it to our internal bug report?
Chris
Chris,
Thanks for starting a new thread.
The problem seems to be local to my computer. Yesterday I tried the same thing on another computer with Firefox & Flash Player (did not check the versions). It worked fine. Does it have anything to do with a particular combination of versions ? I also upgraded to Firefox 6.0.2. Still no luck.
To see the problem, open the following URL & click on the tab 'Intra-day Chart' :
http://www.nseindia.com/live_market/dynaContent/live_watch/get_quote/GetQuote.jsp?symbol=WIPRO
Make sure you have the combination Firefox 6.0.2 & Flash Player 10.3.183.7. Otherwise it may probably work.
Sunder
Hi Sunder,
I tried this out on Windows XP, using Firefox 6.0.2 and 10.3.183.10 (today's release) but I was unable to reproduce the problem. Could you give the new build, or our Flash Player 11 rc build a try and see if it still reproduces for you?
Chris
Chris,
I installed & tried 10.3.183.10. But no luck. If you are not seeing the problem, there should be something to do with Firefox settings or some other program on my computer is causing this problem. I had problem with my Yahoo Mail & it was solved after I removed the Anti Phishing program on my computer. By the way I have Windows XP SP3.
I am ready to try 11 rc. But is there a way to go back to 10 if I have a problem (at least now things are fine on IE) ?
Sunder
Yes, you can definitely go back by using the uninstaller linked at the bottom of the FP 11 RC download page. If you install only the Flash Player for all other browsers (not IE) then IE should remain on 10.3.183.10 (or whatever you have installed.) If you run into any problems going back please let me know and I'll help you out.
Chris
I want to stay with 10.3.183.10 for now. Are there any programs on Windows which may affect the performance of Flash Player ? How do I find this ?
In Firefox when I move across the chart, I can see a moving hand & a dot along the curve & a big stationary filled circle at the top left hand corner outside the chart. Does this tell something to you ?
Sunder
I saw the same hand/arrow combination on my system. Were you able to create a new bug over at bugbase.adobe.com?
I tried with Firefox 3.6.22 & Opera 11.5. Still it does not work. So clearly it is not a browser problem. It has something to do with newer releases of Flash Player. Where do I get older versions for me to try ?
I have added the bug on bugbase.adobe.com (the connecting link in your post did not go there).
Sunder
Hi Sunder,
You can find previous versions of the player here: Flash Player archived versions
Before going back, make sure you follow the instructions on this page for uninstalling.
Chris
Chris,
Here is the shocker. I had told you it works fine on my friend's computer. He has Firefox 3.6.22 & Flash Player 10.2.152.32. Yesterday with great expectations, I tried this combination on my computer. Still it does not work. What do you say about this ? For some reason all versions of Flash Player seem to work well with IE. Do you think Java versions have something to do with Flash ?
I will be on these older versions for a few days hoping you will give me some solution. After that I will go for the latest versions of both & forget using Flash Player on Firefox forever.
Sunder
Message was edited by: sunder.rao
Can you try if clearing the Flash Player cache fixes this? Follow the instructions in http://forums.adobe.com/thread/892474
I cleared the cache. But no improvement.
Now I have moved to Firefox 7.0.1 & Flash Player 10.3.183.10. Still the same problem.
I have good news. I upgraded to Flash Player 11.0.1.152 on Firefox 7.0.1. Now the tooltips are working. I will probably not upgrade my Flash Player for a Iong time in future. I suggest you release versions less frequently after extensive testing.
