5 Replies Latest reply on Sep 22, 2011 5:21 AM by Peter Spier
    ID import of Excel what has changed from CS4 to CS5 (CS5.5)
    romanobstuder Level 1
      Hi all
      I am writing ID scripts that clean up the formating on finanzial data. I need to fix up hundrets of tables, hence the scripting.
      As my client has not moved from CS 4 to CS 5.5 the script create unexpected results.
      As it turns out the import of the same Excel Sheet in CS4 vs CS 5.x creates a different starting file. (The script picks up on the lines, and this is where things go wrong)
      Here is the source file in excel:
      Here is the import in CS 4
      Here is the import in CS 5.5
      As you can see there is many more lines in the import of CS 5.5. (I also tried CS 5)
      I have tested different Excel source files and I consistantly get bad results, that is the ID file looks different from the Excel source.
      Question:
      Has anybody else found this issue.
      May this be a bug in the new CS versions?
      Any help/hints greatly appreciated
      Romano
