0 Replies Latest reply on Sep 20, 2011 4:42 PM by JChanowitz
    Running a Flash Builder 4.5 Mobile BlazeDS Application on the Device
    JChanowitz
      I've been developing a Flex Mobile application in a Flash Builder 4.5 mobile project.  The project uses a java/blazeds server, which is a spring application using the spring blazeds integration. I created the project with the Root URL property in Flex Server settings set to localhost (http://localhost:8080/myServerApp), and all has worked well.  I'm now trying to run the application on a usb connected android device, and am getting a warning that the device can't access my localhost location.  I changed localhost in the Root URL property to the ip of my workstation on the local wifi network the device and workstation are connected to (say http://10.0.0.2:8080/myServerApp), and receive the following error stack:
      ArgumentError: Error #2004: One of the parameters is invalid.  url: 'http:'
                at flash.net::NetConnection/connect()
                at mx.messaging.channels::NetConnectionChannel/internalConnect()[E:\dev\4.5.1\frameworks\pro jects\rpc\src\mx\messaging\channels\NetConnectionChannel.as:240]
                at mx.messaging.channels::AMFChannel/internalConnect()[E:\dev\4.5.1\frameworks\projects\rpc\ src\mx\messaging\channels\AMFChannel.as:307]
                at mx.messaging::Channel/connect()[E:\dev\4.5.1\frameworks\projects\rpc\src\mx\messaging\Cha nnel.as:884]
                at mx.messaging::ChannelSet/connectChannel()[E:\dev\4.5.1\frameworks\projects\rpc\src\mx\mes saging\ChannelSet.as:1707]
                at mx.messaging::ChannelSet/reconnectChannel()[E:\dev\4.5.1\frameworks\projects\rpc\src\mx\m essaging\ChannelSet.as:1809]
                at flash.utils::Timer/_timerDispatch()
                at flash.utils::Timer/tick()
      When I change the root url back to localhost, the error persists, and the only way to recover is to start a new project.  Am I doing something stupid or what?  Any help is greatly appreciated.
      Jay
