> There is no need, but very seldom is there any harm.
Yes, but it doesn't make any *sense*, does it? As the OP so
in delicately
put, CFML isn't XML-compliant, and *cannot* be XML-compliant,
so what's the
point of peppring your code with meaningless slashes?
> Personally I find it easier to put the slash in, then
always thinking.
Good god. Really? Do you not think that perhaps you might be
in the wrong
line of work then?
> I'm now witting a line of XHTML, I'm now writing a line
of CFML, I'm now
This could well be part of your problem (other than the
reluctance to
think, that is). If you plan your code, then the bulk of your
CFML will be
in one set of files, and the bbulk of your mark-up will be in
another set
of files. The mix of the two should be minimal.
Just as a matter of interest, how do you cope with:
1) <cfif> / <cfelseif> / <cfelse>
constructs;
2) the string concatenation operator;
3) < > operators in embedded JS and SQL statements;
4) [etc]
It's a fool's errand.
Adam
