21 Replies Latest reply on Sep 22, 2011 5:34 AM by Peter Spier
    Imbalanced lines with text wrap
    Sam5678
      I'm using ID 5.5, and have noticed a really annoying thing I can seem to remedy easily.
      When I rotate an image that has text wrap applied, the text next to it is pushed away at varying rates, line by line, so I'm left with a ragged appearance:
      You can see the first and fourth lines are closer to the bounding box than the middle two
      I've tried different indents, different text wraps, different point sizes, loads of stuff, but still the text shifts in a non-uniform way.
      Surely it can't be that hard to get text 'hugged up' against a rotated text wrap ... Is the only option to create indents for each line that follow the gradient of the picture? Or manually adjust the wrap frame?
      Any suggestions?
