5 Replies Latest reply on Sep 21, 2011 4:32 PM by kglad
    Slower and slower over time
    JeffKershner
      I have a dashboard I created using Flash CS5 using CS5.5 and ActionScript 3.  It seems that while this dashboard is running, the FPS gets slower and slower over time (over several hours).  I am thinking that I might have a memory leak but I am not sure how to find out.
      The project is a Flash Projector exe that loads 8 independent swfs.
      Each swf file essentially calls a  web service and gets XML data.  They then dynamically create a bunch of TextFields, assigns an event listener (Event.ENTER_FRAME) and animates across the screen.
      When the TextField goes off the screen, I clean up the Text field by removing the EventListener, removing the TextField and setting the TextField to null.
      I am new to flash.  What might I be doing wrong?  Any suggestions where to look?
      thanks,
      --Jeff
        • 1. Re: Slower and slower over time
          the most common problem causing that (and requiring hours for the problem to become appreciable) is creating an increasing number of objects and failing to gc unneeded objects.
          • 2. Re: Slower and slower over time
            JeffKershner Level 1
            This is what I believe is happening.  I don't see what I might not be freeing.  I remove all event listeners and remove the TextFields from the display list.  Is there anything else I need to do?
            Currently I am displaying the frame rate.  I see a frame rate starting at 30 and going down to 8 after several hours.
            I also just started to display the memory:
            tf.text = Number( System.totalMemory / 1024 / 1024 ).toFixed( 2 ) +' Mb';
            I am interested to see if when the FPS goes down to < 10, if the memory is much larger.
            Are there any tools that might help debug what might be happening?
            • 3. Re: Slower and slower over time
              i don't know of any tools that will help you pinpoint the problem.  but you need to do more than just remove objects from the display list and remove listeners:  you need to null all object references.
              • 4. Re: Slower and slower over time
                Yeah, like I said in my original post:
                If you have any other suggestions, point them my way.  Thanks!
                • 5. Re: Slower and slower over time
                  again, that's not necessarily enough:  you need to null ALL object references.
                  if you did that all that, your objects would eventually be gc'd long before your app started to slow.
