1. Re: Issues with Panarama's in Adobe PShop CS4 extended
Noel Carboni Sep 21, 2011 1:57 PM (in response to KateMorgan)Chances are you simply haven't overlapped the shots enough for it to find the commonality between the shots - or something changed between shots. I have had very good luck with Photoshop's Photomerge function if I overlap shots by about 1/3 each.
Is there water in your shots (e.g., with waves on the surface)? That changes from second to second at the detailed level.
Could you make small versions of the shots that don't seem to want to stitch together and post them here? I might be able to better help nail down the reason it's not stitching them after looking at them.
-Noel
2. Re: Issues with Panarama's in Adobe PShop CS4 extended
KateMorgan Sep 21, 2011 2:00 PM (in response to KateMorgan)Wow.. thanks for the speedy and very informative reply Noel. Yes....they are water...and its very possible I did not over lap enough. This makes sense. I will attempt another one soon and see how it works. If I still have issues I will post my results here for you to see. Thanks!
